AI is now available in KeyShot Studio! AI Shots gives you three new ways to amplify your creativity — whether you’re exploring styles, building scenes, or dreaming up what’s next. Everything runs locally and fits right into your existing workflow, with you in full control.
Make this 360° globe-trotting turntable in AI Shots
7 simple steps to create your global turntable
KeyShot Studio Assistant Product Manager Saskia Failla dreamed up this globe-trotting scene with AI Shots. Be sure to update to 2025.2 in order to access the new AI tools in Studio.
1. Import the model, center it and set it to the ground.
2. Adjust the camera so that the pivot point is in the middle of the screen. The first view is from the side, in this case 0 degrees.
3. Save the camera.
4. Start AI Shots: click on "Start AI Engine" and select Restyle mode. (Available in Studio 2025.2)
5. Change the number of generated images to 2-3, depending on the prompt, for some more results to choose from.
6. Repeat steps 1-5, changing the camera rotation (Azimuth value in Camera Settings by 5 degrees)
7. Repeat as desired, and put it all together in your preferred video editing program when done.
Ready to dive into KeyShot Studio AI?
Get the full rundown and helpful prompting tips here.
