How To Add A Textured Logo in KeyShot
If you have a company logo on a product, it’s pretty common to need a logo as a material (like a chrome sticker) but not have the logo modeled in 3D. Modeling a logo can create extra work and slow the model down, but KeyShot provides a simple way to achieve the same result, much faster.
Download KeyShot .ksp
arrow_down-green
keyshot-textured-label-02-200In the original model, we offset a surface where our logo will be placed, approximately the size we need to logo to be. Once this is set up, we’re ready to import into KeyShot. Here is the 3-step process for applying the logo and setting the texture.
First, apply the logo as a Color texture to the offset surface created in the original part, making sure to scale it correctly, un-check Repeat, and in this case change the projection to Planar Y. This gives us the logo as a color on our chrome surface.
keyshot-textured-label-03
2. Add logo as a bump map
Next, add the same logo as a Bump map. This will give our logo a raised appearance. Adjust the bump height to achieve the preferred look. (In this case, I’ve dropped the Bump Height to .1.)
keyshot-textured-label-04
3. Add logo as an opacity map
Lastly, add the logo as an Opacity map. Since this is a PNG with transparency, I’ve changed the Opacity Mode to Alpha, since an opacity texture normally uses black and white values (white = visible, black = invisible).
keyshot-textured-label-05
Now as you can see, our logo will have color, texture, and the shape cutout using only images! Using textures is a great way to reduce modeling time and improve your workflow in KeyShot.
keyshot-textured-label-06
Bonus tip:
Slightly blurring bump maps will provide better results for smooth, clean surfaces. In the image below, you can see a comparison using a blurred bump texture. It was also made as a grayscale image, with the gradients removed.
keyshot-textured-label-07
