KeyShot Studio AI KeyShot Studio AI KeyShot Studio AI KeyShot Studio AI KeyShot Studio AI
Restyle mode
Generate new style directions in seconds* using a simple prompt—keeping your original layout intact and your creative momentum flowing.
Learn more
*Restyle at 1280 by 720 pixels takes 15 seconds to generate, powered by RTX 5080. Performance may vary, depending on GPU utilized.
KeyShot Studio AI KeyShot Studio AI KeyShot Studio AI KeyShot Studio AI KeyShot Studio AI KeyShot Studio AI KeyShot Studio AI
Background mode
Turn your rendered product images into compelling scenes with AI-generated environments—all generated locally, without compromising privacy or context.
Learn more
Background mode
Learn more
Imagine mode
Create quick, high-quality visual concepts instantly. Spark new directions, unblock ideas, and create conceptual imagery for accelerated decision-making, fostering alignment between teams — all before modeling anything.
Learn more
Better results, faster than ever. Get the power of KeyShot Studio.
Privacy & security with localized AI
No internet connection is required, and no data leaves your machine. Use generative image AI—even on confidential projects—without risking security or leaks.
Unlimited generation, infinite options
Without the bounds of credits or limits, you can keep generating ideas, styles and backgrounds until something clicks.
Included free with your KeyShot Studio subscription
KeyShot Studio AI is built right in, at no additional cost, to the latest update of KeyShot Studio (2025.2).
Soren Abildgaard
Chief Executive Officer / KeyShot
KeyShot’s AI vision
“What sets KeyShot’s AI apart is our commitment to user control and performance. The creative process should be fluid, not constrained by technical barriers. Our new AI tools provide a significant leap forward for designers, transforming how you work while maintaining optimal privacy and security. But this is just the beginning. We have an exciting roadmap ahead, with even more innovative features and AI enhancements coming soon. Our mission remains unchanged: to give creators the tools they need to turn vision into reality, faster and more intuitively than ever before, with KeyShot. ”
Learn more
Logo
Explore AI Across KeyShot
KeyShot DAM automates manual tasks and integrates with your existing systems, boosting content distribution efficiency by up to 90%.
Frequently Asked Questions
How do I use the new KeyShot Studio AI features?
Open up KeyShot Studio and make sure your software is updated to the latest version (2025.2). Once your software update is complete, you should see a button titled “AI Shots” in the bottom right corner of the Studio interface. Click on “AI Shots” to download the AI model, and once complete you will be able to use the new AI features.
Are there additional costs to use KeyShot Studio AI?
No, KeyShot Studio AI features are included within all KeyShot Studio subscription licenses.
Do I need an internet connection to use AI Shots?
Only once. The AI model is downloaded the first time you use the feature. After that, AI Shots runs entirely on your local machine — no ongoing internet connection required.
Does the AI model collect data?
No. The model doesn’t learn, adapt, or collect data. Once downloaded, it stays the same unless you choose to install an update.
Will I have to update the AI model later?
No. If an updated model becomes available, you’ll be prompted to download it — but you can continue using the version already installed on your machine.
Can I use AI Shots to create content for public or commercial use?
Yes — just be sure to review the results first. The model can’t guarantee outputs are free of copyright or trademarked elements, so it’s up to you to ensure the content is appropriate for public release.
What hardware does KeyShot recommend for using AI Shots?
Minimum System Requirements:
  • Windows: NVIDIA or AMD GPU with at least 16 GB memory
  • Mac: M1 or newer CPU with at least 16 GB memory
  • CPU-only rendering is supported but significantly slower and not recommended.
Performance Recommendations:
  • Start with low-resolution images (e.g., 512 × 512) to minimize memory usage and rendering time.
  • Higher resolutions require more memory and take longer to generate.
Rendering Behavior:
  • AI Shots automatically enables CPU rendering to free up GPU memory.
  • Do not enable GPU rendering while using AI Shots due to high memory demands.
  • Avoid running other GPU-intensive tasks simultaneously, as they may degrade AI Shots performance.
Does VRAM affect image resolution or performance?
Yes. The amount of VRAM determines the maximum resolution of generated images — more VRAM generally allows for higher-quality outputs.
Try KeyShot Studio AI for free
Get a two-week trial of KeyShot Studio featuring the new AI tools, enhanced light and materials support, and more.
