KeyShot Studio
The top 7 rendering tools for automotive design in 2026
auto-rendering-velare-luxury-by-lee-cant-keyshot
Automotive teams render for different jobs: press stills, design review, dealership configurators, commercials. The tool that’s best at one is rarely best at all four. Lee Cant batch-renders an entire alloy wheel range in KeyShot Studio with identical angles and lighting. Autodesk VRED’s 2026 Vulkan renderer holds assemblies of 100,000-plus parts in real time for OEM review. Both are fast, and they’re built for different work.
Below are 7 tools sorted by the job each does best. Some are real-time engines, some are final-frame renderers, and several do both. For each one you’ll find the features that matter for that job, where it falls short, and what else covers the same ground.
KeyShot Studio for press and product imagery without a photo shoot
KeyShot Studio’s most documented automotive use is replacing the photo shoot. You bring in CAD or polygon data, apply materials and lighting in a standalone real-time view, and render final marketing images.
Lee Cant works almost exclusively in automotive product imagery. His projects include the Rolls-Royce Cullinan and a large range of alloy wheels, rendered with identical angles, lighting, and setup across the catalog. He renders without backgrounds, so there’s no cutout work after. A photo shoot for the same set would need a studio, physical parts, and hours of post-processing.
Nils Piirma produced the official press images for the Koenigsegg Gemera, visualization for the Jesko and Regera, and the Genesis Mint press images in KeyShot Studio. He does the lighting and effects in KeyShot Studio and finishes with light post-processing.
Standout features for this job
  • Studios save combinations of finish, scene, and lighting in one file. Cant sets up every finish once, then batch-renders the whole set instead of rendering scenes one by one.
  • GPU Mode switches the real-time view and final renders to GPU ray tracing in one click, with multi-GPU scaling, and back to CPU when you need it. Piirma credits GPU rendering for letting him iterate on a time crunch. Network Rendering takes GPU jobs too, so a large batch doesn’t tie up the workstation.
  • Solo Mode puts all rendering power on the selected part, so material edits on one wheel or trim piece update faster.
  • The Material Graph builds paint, chrome, and leather finishes node by node inside KeyShot Studio. Cant says it gets him “pretty much any material I need.”
  • Labels let JONSIBAL Designworks map livery designs onto 3D race cars and adjust logo placement and proportion on the fly. Their widebody kit for Papadakis Racing’s Toyota GR Corolla took first place at the opening round of the 2022 Formula Drift season.
  • Geometry tools split objects and surfaces and fix normals without a trip back to the CAD tool. Piirma uses them for parts that should have been split during modeling.
What it’s not good at: KeyShot Studio doesn’t build drivable environments or virtual showrooms. Teams that need those add Unreal Engine or Unity for that part of the job.
Best fit: OEM marketing and press teams, design studios, engineers, and independent visualization artists who need photoreal stills without a photo shoot.
Autodesk VRED for OEM design review and virtual prototyping
VRED puts a design in front of people who didn’t build the model, usually at OEM scale. At Kia’s Europe Design Center, the CGI team uses VRED with a Varjo mixed-reality headset to switch between a physical clay model and its virtual counterpart during a live review. BMW streamed VRED Core models from the cloud to workstations, iPads, and XR headsets at Autodesk’s AIF25 event.
  • The Vulkan renderer, new in VRED 2026, handles assemblies of 100,000-plus parts in real time. That’s enough for a whole vehicle’s trim, fasteners, and interior in one review session.
  • Live Referencing with Alias lets surface modelers and visualization specialists work on the same project with instant updates, so a review doesn’t wait on a re-export.
What it’s not good at: VRED is built for internal review. It’s a poor fit for a lightweight configurator on a public website, and it carries a high cost and a steep learning curve.
Best fit: OEM design studios and enterprise teams in the Autodesk pipeline who review full vehicles at CAD-accurate scale.
Other tools that also do this job
  • KeyShot Studio with KeyShot Studio VR takes material and design review into a headset. VR launches from the KeyShot Studio toolbar in one click and supports Varjo, Meta Quest, HTC Vive, and Valve Index headsets. VR Connect puts reviewers in different locations into the same virtual session. LiveLinking plugins for Rhino, PTC Creo, Siemens NX, Autodesk Fusion, Onshape, and others update the scene when the CAD model changes.
  • Unreal Engine fits review work when the same assets will also become a customer-facing configurator.
Unreal engine for interactive vehicle configurators
Product visualization systems can run in more than 1,000 showrooms now and let a customer see their exact configuration from any angle even when that car doesn't physically exist yet in Unreal. This is how Audi's salespeople can show photorealistic visuals on an iPad without installing anything. McLaren also currently builds its GT configurator through a single Unreal-based pipeline instead of maintaining separate 3D-dealership and 2D-online workflows and can cut both production cost and time significantly.
Standout features, tested against this job:
  • The Variant Manager and Blueprint visual scripting let a team build paint, trim, wheel, and interior options without custom C++ code. Audi's in-house team used this to connect an automated importer directly into Unreal, which is what made maintaining 1,000-plus showroom deployments feasible without a large dedicated engineering team.
  • Pixel streaming delivers full-fidelity visuals to any device through a browser by processing the massive interactive 3D application on a high-performance cloud server, then broadcasting the real-time frame outputs as a low-latency live video feed.
  • Ray tracing and physically based automotive materials bring photorealism into the customer decision-making process. This matters because a configurator needs to help customers make decisions, not simply create attractive renders.
What it's not good at: it can deliver showroom-grade realistic renderings, but would need a considerably more technical setup and pipeline development than dedicated automotive visualization tools (KeyShot or VRED).
Best fit: OEMs and agencies building customer-facing configurators or dealership tools that need to scale across many devices and locations.
Other tools that also do this job:
  • Unity is positioned similarly for configurator deployment and has a lighter runtime footprint suited to web and mobile targets.
  • KeyShot is an alternative for product-focused configurators where the goal is exploring vehicle variants. Its Configurator Wizard and Web output enable faster deployment with less technical overhead, while Unreal remains better suited for large-scale interactive experiences.
Unity for lightweight web and mobile configurators
Teams building configurators pick Unity when reach matters more than maximum fidelity. Its WebGL and mobile builds are small enough to run on a customer’s phone or a standard browser without cloud streaming. Its documented automotive role leans to web and mobile, where Unreal’s leans to showroom scale.
  • Small runtime builds load in a phone browser without the hardware Unreal’s full ray tracing needs.
  • Web and mobile build targets package one project for broad device coverage.
What it’s not good at: out of the box, its material and lighting quality trails dedicated product renderers, so photoreal paint and chrome take significant scene work.
Best fit: teams that need a configurator on as many devices as possible and can accept less photorealism.
  • Unreal Engine when showroom-grade fidelity matters more than reach.
  • KeyShot Studio Web when the configurator needs KeyShot Studio’s materials and the team would rather upload a scene than build an app.
Octane Render for GPU stills inside Cinema 4D, Maya, and 3ds Max
Octane is an unbiased GPU path tracer that runs as a plugin inside host applications like 3ds Max, Maya, and Cinema 4D. Artists get close-to-real-time feedback on light and reflections without leaving the modeling app.
  • Unbiased GPU path tracing gives fast feedback on complex light paths and refraction while you adjust a scene.
  • Host-app plugins keep freelance artists in the tool they already model in.
What it’s not good at: it has no automotive-specific material library, so convincing car paint and chrome take manual shader work.
Best fit: freelance CGI artists and small studios already working in Cinema 4D, Maya, or 3ds Max.
  • KeyShot Studio has LiveLinking plugins for the same three hosts and ready-made paint, metallic paint, and metal materials that skip the shader-building step.
  • Redshift for teams in Cinema 4D or Houdini that want a biased GPU renderer.
Blender for early-stage automotive modeling
Blender is free, and in automotive work it’s usually the modeler feeding a dedicated renderer. Lee Cant and JONSIBAL Designworks both model in Blender and render in KeyShot Studio. At Tata Motors European Technical Centre, modelers produced nine iterations of a base car in five days in Blender, work the team said would take ten to fifteen days in Alias (Blender user story, 2015).
  • Polygon modeling for form studies skips NURBS precision in the early stages. Tata’s team used Blender to get design volumes signed off, then moved to Alias for the next steps.
  • KeyShot Studio for Blender LiveLinks a Blender scene into KeyShot Studio, so a model change in Blender updates the KeyShot scene without re-importing. It carries animation across too.
What it’s not good at: there’s no vendor support line, and as a final renderer it needs more manual material setup per project.
Best fit: design teams doing fast early-stage form iteration, and students or solo designers building a portfolio without software cost.
  • KeyShot Studio for final materials, lighting, and output once the form is set.
  • Autodesk Alias for high-precision NURBS surfacing once early forms are blocked out.
Redshift for automotive commercials in Cinema 4D and Houdini
Redshift is a biased GPU renderer built for production animation. Motion studios use it for automotive commercials, where render time per frame decides the schedule.
  • Biased sampling approximates light in low-impact areas like distant geometry and dark corners, cutting frame times across long animation sequences.
  • Out-of-core memory moves geometry and textures from GPU memory into system RAM when a scene outgrows the graphics card, so heavy vehicle scenes don’t crash mid-render.
What it’s not good at: as a biased renderer, it takes more artist judgment to match KeyShot Studio’s physically accurate lighting without a result that looks slightly artificial.
Best fit: studios producing automotive commercials or motion content in Cinema 4D or Houdini.
  • Octane Render is the unbiased GPU alternative in the same Cinema 4D workflow.
  • KeyShot Studio handles product-focused animation (camera moves, part moves, material changes) with the same materials used for stills, and LiveLinks from Cinema 4D.
Should you render in Alias or Autodesk Fusion?
Alias and Fusion are surfacing and parametric CAD platforms. Their built-in rendering is there to check surfaces while you model. For final photoreal output at speed, send the model to a dedicated renderer. Fusion has a KeyShot Studio plugin with LiveLinking, and Alias models come into KeyShot Studio through direct import.
KeyShot Vs VRED Vs Blender: feature comparison of Automotive 3D visualisation tools
Tool Best for Real-time approach Deployment considerations
KeyShot Studio Press and product stills without a shoot, VR design review, browser configurators Real-time CPU or GPU ray tracing, switchable Standalone app with LiveLinking plugins for major CAD and 3D modeling tools. KeyShot Studio VR and KeyShot Studio Web extend the same scene to headsets and browsers
Autodesk VRED OEM design review and virtual prototyping Real-time ray tracing (Vulkan renderer in 2026) Enterprise cost and learning curve; built for internal review
Unreal Engine
Interactive configurators and showroom tools
Real-time ray tracing, Pixel Streaming Needs developers and pipeline work
Unity Lightweight web and mobile configurators Real-time rasterized Small builds; less automotive-specific tooling out of the box
Octane Render GPU stills for freelancers and small studios Unbiased GPU path tracing Runs inside a host app (3ds Max, Maya, Cinema 4D)
Blender Early-stage form iteration Eevee (real-time) and Cycles Free; less mature automotive materials as a final renderer
Redshift Automotive commercials and motion Biased GPU rendering Runs inside Cinema 4D or Houdini; lighting needs artist judgment
Should your team use one rendering tool or several?
One renderer is enough when its features cover your jobs. KeyShot Studio handles materials, lighting, geometry cleanup, and final output in one application, which is why Cant and Piirma bring in a finished model and produce the press image there, with light post-processing after. Add KeyShot Studio VR and KeyShot Studio Web and the same scene also serves design review and a browser configurator.
When a job falls outside what your main tool is built for, a second tool is the right call. Most rendering tools now hand off to each other. KeyShot Studio for Blender LiveLinks a Blender scene into KeyShot Studio, so a change in Blender updates the KeyShot scene without re-importing or rebuilding materials. VRED does the same with Alias through Live Referencing.
If you’re pushing VRED to be a public configurator, or building car paint by hand in Octane, add a tool built for that job.
Try KeyShot Studio free on your own vehicle data.
Written by Chidinma Iwu
Chidinma Divine Iwu is a content strategist covering tech, ecommerce, design, and personal finance. Her articles can be read in ClickUp, Feats, Forbes Advisor, the Daily Mail, etc. She's almost always on Twitter @Chidxnma, tweeting spontaneously and wishing things were better for women.
Keep reading
Related posts
Get the latest from KeyShot
