Updated Plugins for Creo and Pro/ENGINEER with KeyShot Exporter
Irvine, CALIFORNIA, April 4th, 2012 – Luxion, a leading developer of advanced 3D rendering and lighting technology and makers of KeyShot®, the first real time ray tracing and global illumination program for 3D rendering and animation, has released version 1.3 of the KeyShot plugins for both CreoTM and Pro/ENGINEER® 3D software packages.
These new plugins bring a whole new level of functionality to the workflow between Pro/ENGINEER, Creo and KeyShot. With this release users now have the ability to export a KeyShot .bip file without the need of having KeyShot installed. This complements the workflow through the entire design process allowing modelers to send a compact file format through the pipeline for rendering and animation.
Model developed in Pro/ENGINEER, rendered in KeyShot. Image: Adam Wist NCD Nietfeld GmbH
The new fuctionality for .bip export is completely compatible with the updated 1.3 plugins (available here) and KeyShot 3.1 (available here).
“The new plugins provide designers and engineers a faster way to deliver models to one another.” said Thomas Teger, VP, Products and Strategy at Luxion. “With a one-button export of the KeyShot file directly from the Pro/ENGINEER or Creo interface, anyone can now output a KeyShot file, and that makes it a standard file format for any Pro/ENGINEER or CREO user. On top of that, the .bip file maintains the camera settings, assembly structure, part level appearance and the orientation of the model. It further speeds up the process and allows one to send files in the KeyShot format rather than having to share IP in form of actual geometry.”
Additional enhancements to the plugin include:
  • Tessellation refinement
  • Orientation of assembly upon import
  • Use of part level appearances
  • Optional use of assembly level appearances (Creo only)
  • Ability to merge identical parts into one single material group
  • Optional export of Pro/ENGINEER / Creo orientations
  • Automatically launch KeyShot and import assembly when installed.
  • Numerous bug fixes
The plugin is absolutely free and can be downloaded immediately from the KeyShot website. Pro/ENGINEER and Creo versions currently supported by the plugin are Pro/ENGINEER Wildfire 3-5, Creo/Elements Pro. Creo 1.0. KeyShot is available for PC and Mac and can import native Pro/ENGINEER and Creo data on either platform without the need of the plugin.
About Luxion
Luxion is a leading developer of advanced 3D rendering and lighting technology. KeyShot is the first realtime ray tracing application that uses a physically correct render engine based on scientific research in the areas of scientifically accurate material representation and global illumination. Addressing the visualization needs of designers, engineers, marketing professionals, photographers and CG specialists, KeyShot breaks down the complexity of creating photographic images and animations from 3D digital data. Luxion’s customer list includes many of the Fortune 1000 product manufacturers and major industrial design companies including Dell, HP, Microsoft, Motorola, Nokia, Procter & Gamble, IDEO and SMART Design. For more information visit https://www.keyshot.com.
Press contact:
Luxion, Inc.
Josh Mings
Marketing Manager
josh@luxion.com
+1-(949) 274-8871
KeyShot is a registered trademark of Luxion ApS. All other company and product names may be trademarks of their respective owners.
