Optimizing Your Workflow: Using the KeyShot Benchmark Tool
Category:
This week, we released KeyShot 9.3 and with it updates to KeyShot Studio Viewer and the new KeyShot Studio Benchmark tool. KeyShot Studio Viewer is a free, stand-alone application for sharing KeyShot Studio scenes for others to view and interact with your visuals and the KeyShot Studio Benchmark is a simple, yet powerful tool to test your CPU and/or GPU and evaluate their performance.
KeyShot Studio Benchmark Tool
Before you start you'll need KeyShot Studio Viewer. You can download the free KeyShot Studio Viewer and use it to run benchmarks across different computers and share your KeyShot Studio scenes with others.
1. Open KeyShot Viewer
After a quick install, you can open KeyShot Studio Viewer and see options to open a KeyShot Studio scene, open a recent or demo scene, take a tour, or run the benchmark. When you select Benchmark the first time, it will download the sample benchmark scene.  Once that's all set, the Benchmark tool dialog will open.
keyshot-viewer
2. Run KeyShot Studio Benchmark
To get accurate results, it’s important to close all other applications before running the test. Also, if you’re running tests across multiple machines, be sure to use the same version of KeyShot Studio Viewer on each. If you have a system with a supported GPU, when you click Benchmark, you will see options to test CPU, GPU, or both. If your system doesn't have a supported GPU, when you click Benchmark, it will run a benchmark for the CPU. When the benchmark starts, a window showing the benchmark's progress will appear.
3. View Benchmark Result
Once that’s finished, the results will appear next to the chosen test. And now that you have these, you may be wondering...
What Do KeyShot Benchmark Results Mean?
The results are multiples based on render time. Higher scores are better and scores higher than 1.0 are better than the reference system. The reference system is an Intel Core i7-6900K CPU @3.20GHz, 2601 Mhz, 8 Core(s). A score of 1.0 matches the speed of the reference system. A score of 2.0 would be double the speed of the reference system.
The GPU benchmark follows the same CPU baseline, based on that same machine. Typically, you’ll get much higher numbers with a GPU test. For reference, you can check out this document from NVIDIA (PDF). For example, you can see a big difference between the power of having two Quadro RTX 6000 cards, versus the CPU baseline of 1.0.
You can learn more about KeyShot Studio Viewer and Benchmark in the KeyShot Studio Manual. Here's a video of the process of using KeyShot Studio Benchmark from start to finish:
We would love to see what you create with this tip. Visit the KeyShot Community forum to see what others are creating and share your own work. And if you have a suggestion for another tip, please share it with the community.
Need KeyShot Studio? Check it out here.
Download KeyShot Viewer
The KeyShot Benchmark Tool is part of the free KeyShot Viewer. Download KeyShot Viewer to run benchmarks and share your KeyShot scenes with others.
