KeyShot Studio Network Rendering
Your Own Super-Fast Rendering Network
Render faster with the CPU and GPU power of all your machines on one network.
Buy KeyShot Studio Network Rendering
$62.42 / user / month
Billed annually -   $749.00
Add to cart
Solicitar informações
More cores means more power
Building your own network farm is fairly simple: the more KeyShot Network Rendering “cores” you add, the faster your animations and complex images come to life. How many cores you need depends on several factors, including the complexity of your final scene, your computing power, and if your computers use CPU or GPU.
How many KeyShot Network Rendering cores should you purchase?
Freelancers, small business, design firms and large international companies require different needs. Take out the guess work, and let us help you select the best package for your rendering needs and budget.
How much time can Network Rendering save you?
Here’s an example a KeyShot user shared with us before and after adding KeyShot Network Rendering. Users with Network Rendering say they cut their rendering times by at least half. The time you save will depend on many things, like the cores you buy and the complexity of your scene.
30 minsAMD Ryzen Threadripper
3960X 24-Core Processor 3.8 GHz
30 minsKeyShot Network Rendering
224 Cores
Spend time on your design instead of waiting for your render
Freelancers
Offload renders to an old computer and get back to designing.
Small businesses and design firms
Keep your team productive — dedicate one machine to rendering.
Large and international companies
Create multiple render farms and multiply productivity company-wide.
Easily manage your machines and jobs
Optimize your network
Connect to multiple computers on one network and utilize all of your hardware to significantly and easily increase your rendering capacity and output. View progress and final images in an easy-to-use hub. Render jobs can be submitted by any network user.
Job management
Manage your tasks, scheduling them for use at specific times or days. Set the number of cores allowed for each and see immediately what computers are allocated, with the ability to utilize computer power without KeyShot being installed.
User management
Manage all of the users in your organization with the ability to assign specific privileges based on role or usage. Easily add, remove or change passwords and privileges for each user all from a single screen within the user and group management system.
We love KeyShot’s Network Rendering. We can render overnight in a room full of CAD workstations that otherwise sit idle.
Network Rendering has been a big asset, allowing us to ship off renders as soon as they’re set up, and get back to working on the next one. We can iterate quickly without investing a ton of time waiting for each render to finish. Instead, our farm does the work for us.
Interested in KeyShot Network Rendering?
We’ll set up a quick consultation to make sure you get the correct amount of cores for your needs.
