Revolutionize Your Design Process with KeyShot: Fast 3D Rendering
Start Today
Download a free trial of KeyShot with examples to see how easy 3D rendering can be.
See it in action
Schedule a live demo of KeyShot to see how easy you can create 3D product visuals.
Experience the fastest, easiest to use 3D rendering tool available. KeyShot provides the most simple approach to create design visualization with more material and color options than ever before, and features that make it easy to create visuals anywhere in your design process. This is why so many trust KeyShot for their 3D visualization.
Key Features:
- Real-time Ray-tracing
- Drag and Drop Materials
- Procedural Textures
- Interactive Labeling
- HDRI Lighting
- Physical Lighting
- Full Camera Control
- Pantone® and RAL® Colors
- Part and Camera Animation
- Focused Caustics
- HDR Editor
- Widest 3D File Format Support
- Plugins for 3D Modeling Software
Amazing 3D renderings. In minutes.
KeyShot is widely recognized as the best 3D rendering software for both Windows and Mac. Communicate your ideas easier, explore concepts sooner, and deliver jaw-dropping visuals faster – Try KeyShot today.
Ready to Try KeyShot?
You’ll be up and running in no time. Download a free trial to experience how fast you can visualize your ideas.
Why is KeyShot the Best 3D Rendering Software?
Easy
You don’t have to be a rendering expert to create photorealistic images of your 3D model. Simply import your data into KeyShot, assign materials by dragging and dropping them onto the model, adjust the lighting, and move the camera. Done.
Powerful
KeyShot can be used with both CPU and GPU. KeyShot takes full advantage of all capabilities of your computer. As your computer gets more powerful KeyShot becomes faster. The performance scales linearly with the number of cores and threads in your system.
Fast
Everything inside KeyShot happens in real-time. KeyShot uses unique rendering technology which makes it possible to see all changes to materials, lighting, and cameras instantly. You donʼt need to hit the render button and wait for minutes or hours to wait for the results. As soon as you assign a material to a part, you will see what a material will look like under the given lighting conditions.
Integrated
KeyShot is tightly integrated with your 3D data. When you import 3D geometry, KeyShot maintains the entire model structure including part and assembly names. Changes made to your model in 3D can import back into KeyShot without having to reassign materials or lighting. In addition, KeyShot can also be accessed directly from within many 3D software packages through a plugin.
Accurate
KeyShot is the most accurate rendering solution for your 3D data and is the first real-time ray tracing application that uses a physically correct render engine based on research in the areas of scientifically accurate material representation and global illumination.
Large data sets
KeyShot can handle extremely large data sets. There are no restrictions on the size of the data set as long as the computer has enough memory available. KeyShot is highly optimized which makes it possible to work with models with tens of millions of polygons even on a laptop.
Amazing visuals. Even faster.
Download KeyShot today to see how fast you can create amazing visuals of your 3D models.
