keyshot-6-400-blk
Amazing renderings. In real-time.
KeyShot is widely recognized as the best rendering software for both Windows and MacOS, and the easiest, most powerful when it comes selling a concept, creating internal presentations, exploring digital prototypes and creating sales or marketing images – all from your 3D data.
Try KeyShot
Interested in seeing what KeyShot has to offer? Download a free trial to experience how fast you can render your models.
Please enter a valid email in order to receive download links and instructions.
Amazing features in the most remarkable user interface for rendering. The most simple approach to illuminate your products and scenes. More material and color options than ever before. Enhancements that completely integrate visual production within your product development pipeline. This is KeyShot.
Key Features:
  • Real-time Ray-tracing
  • Drag and Drop Materials
  • Procedurals Textures
  • Interactive Labeling
  • Real-world HDRI Lighting
  • Physical Lighting
  • Full Camera Control
  • Pantone® and RAL® Colors
  • Part and Camera Animation
  • Focused Caustics
  • HDR Editor
  • Widest 3D File Format Support
  • Plugins for Top Modeling Software
Why is KeyShot the Best Rendering Software?
Easy
You don’t have to be a rendering expert to create photorealistic images of your 3D model. Simply import your data into KeyShot, assign materials by dragging and dropping them onto the model, adjust the lighting, and move the camera. Done.
Image by: Greaves Best Design
Powerful
KeyShot doesnʼt require any special hardware or graphics card. KeyShot takes full advantage of all cores and threads inside a computer. As your computer gets more powerful KeyShot becomes faster. The performance scales linearly with the number of cores and threads in your system.
Image by: Rodrigo Sória
Fast
Everything inside KeyShot happens in realtime. KeyShot uses unique rendering technology which makes it possible to see all changes to materials, lighting, and cameras instantly. You donʼt need to hit the render button and wait for minutes or hours to wait for the results. As soon as you assign a material to a part, you will see what a material will look like under the given lighting conditions.
Image by: Egon
Integrated
KeyShot is tightly integrated with your 3D data. When you import 3D geometry, KeyShot maintains the entire model structure including part and assembly names. Changes made to your model in 3D can import back into KeyShot without having to reassign materials or lighting. In addition, KeyShot can also be accessed directly from within many 3D software packages through a plugin.
Image by: SONIC Design
Accurate
KeyShot is the most accurate rendering solution for your 3D data and is the first real-time ray tracing application that uses a physically correct render engine based on research in the areas of scientifically accurate material representation and global illumination.
Image by: Protograph
Large data sets
KeyShot can handle extremely large data sets. There are no restrictions on the size of the data set as long as the computer has enough memory available. KeyShot is highly optimized which makes it possible to work with models with tens of millions of polygons even on a laptop.
Image by: Adam Wist
Amazing visuals. Even faster.
Download KeyShot today to see how fast you can create amazing visuals of your 3D models.
