Author Topic: Geometry Missing  (Read 11574 times)
Offline cmcconnell
Geometry Missing
« on: February 26, 2013, 05:53:25 am »
I have tried several times to import Inventor 2013 geometry by opening the .iam files with Keyshot. After some time, these models open, but the majority of the parts do not import.
What can I do to make this work?
I have had to export them as a .stp file and import them that way.
Offline bross
Re: Geometry Missing
« Reply #1 on: March 17, 2013, 04:02:52 am »
I agree with you. There is problem between Autodesk Inventor 2013 and Keyshot 4 when you do geometry in sheet metal option then import to Keyshot 4 but part don't import.  :(
« Reply #2 on: March 18, 2013, 06:51:23 am »
Can you please provide an example so we can investigate?
Thanks.
Offline cmcconnell
« Reply #3 on: April 18, 2013, 01:18:59 pm »
Sure - here is an example. this image is the assembly in Inventor Pro 2013 SP1.1 Update 2
this is after import into Keyshot 4.0 Pro
And the inventor assembly can be downloaded from here. The assembly shown is XX0010-FT2-MA0040.
Offline Brandon Davis
  • Jr. Member
    • KeyShot
« Reply #4 on: April 18, 2013, 09:54:56 pm »
Can you provide us with the CAD data? You can send the file via keyshot.wetransfer.com to [email protected] We will investigate the issue here.
Offline DonChunior
  • Full Member
    • BOINC - Donate computing power instead of money
« Reply #5 on: April 19, 2013, 02:44:57 am »
He already wrote, that you can download the models from there and that it is the assembly XX0010-FT2-MA0040.
Offline alanambrose
« Reply #6 on: April 21, 2013, 01:10:22 am »
Yeah me too. Out of 3 models that I have imported into my new copy of KeyShot, 2 had missing sections - and I bought KeyShot only to use with Inventor. That's a pretty poor average, anyone in the KeyShot team think of doing any testing? It's not the customer's job to test your product btw. Lofts seem to do it easily (but that's just what I happen to be using right now). Add a few test cases with lofts to your test suite?
Offline alanambrose
« Reply #7 on: April 21, 2013, 01:22:01 am »
On a slightly different subject, how come Inventor's standard display real-time render is better than Keyshot's 30s render? Some settings somewhere?
Offline alanambrose
« Reply #8 on: April 26, 2013, 01:10:49 am »
Another one - this time from step files. Not sure how the missing square chunk comes about - there's no actual geometry defined there. Can we have a commitment to fix this bug? Timescale?
Offline alanambrose
« Reply #9 on: June 03, 2013, 10:18:31 am »
Ah the silence of a software vendor that can't be bothered to fix obvious bugs...
« Reply #10 on: June 04, 2013, 07:51:07 am »
If you can provide the file we can look into it.
As an alternative we have found that export to CATIA from Inventor will give the best results.
Offline cmcconnell
« Reply #11 on: June 20, 2013, 02:47:17 pm »
See my post above - there is a link at the bottom, under my screenshots...
« Reply #12 on: June 21, 2013, 06:21:10 am »
Yes - I got that. It has been reported to the developer.
Offline cmcconnell
« Reply #13 on: June 25, 2013, 06:58:15 pm »
Thanks.
Offline cmcconnell
« Reply #14 on: September 27, 2013, 02:10:35 pm »
Has there been any progress made with this issue?
