Author Topic: Copy and edit materials  (Read 2806 times)
Offline Robb63
« on: June 25, 2010, 05:54:29 am »
In KS2 when I copy a material (with decal) and paste in on another part when I try to edit that material to position the decal it moves the decal off of the first part over to the part I'm working on.
I've even made a new material in the library and assigned it to the second part and it does the same thing when I try to edit the decal location.
In KS1 If I copied a material and pasted it I could edit it without affecting the original, is there a way to do this in KS2?
  • Guest
Re: Copy and edit materials
« Reply #1 on: June 25, 2010, 07:35:07 am »
Two things:
Make sure you are using the latest version - 2.0.38.
Make sure the materials are NOT linked.
I just tried it and it worked fine. When you copy the material the label may not show up. Simply double-click on that material, go to label, and toggle "enable". Now the label is there.
Offline Robb63
« Reply #2 on: June 25, 2010, 09:57:27 am »
That was it; I had to unlink it then go into edit the material. The decal said it was "enabled", but I clicked it on and off and it came on in the correct location.
Thanks!!
  • Guest
« Reply #3 on: June 25, 2010, 01:17:42 pm »
Excellent! Glad it is working for you now.
Thomas
