Author Topic: KeyShot 4 sneak peak  (Read 11155 times)
Offline DriesV
  • Global Moderator
Re: KeyShot 4 sneak peak
« Reply #15 on: January 19, 2013, 01:02:10 am »
I ran that rendering on a dual Xeon E5-2680 workstation.
I think I grabbed a screenshot from the realtime window after two hours or so? Not entirely sure.
Of course that translucent lamp shade introduces a rendering time penalty.
I tried different materials for the lamp shade too. Then the image resolves much faster, but you don't get that soft diffusion of light behind the lamp.
E.g. I grabbed these shots after 10  minutes rendering or so.
Nr. 1: highly reflective metal shade
Nr. 2: mimicing of original shade in advanced material type
The scene with metal shade does render very fast!
« Last Edit: January 19, 2013, 01:17:45 am by DriesV »
Offline evilmaul
  • Sr. Member
« Reply #16 on: January 19, 2013, 09:14:06 am »
nice, thanks for those info and sharing new tests!
2 hours for such a simple scene though is a little too much :) but I do understand that there is quite a bit going on computational wise.
Offline DriesV
  • Global Moderator
« Reply #17 on: January 19, 2013, 10:27:36 am »
Yes, I guess that what I did is computationally very expensive. The light bulb is literally throwing around photons in order for a defined projected light pattern to form. You realy see this as the rendering progresses.
That's why it's so great we'll be able to use IES profiles! Then we won't need to model fixtures and KeyShot doesn't need to churn out a light distribution pattern on the fly. The luminous parameters are right there, served in a text file! 8)
I just did this scene to see if it could be done in KeyShot. And boy, can it be done! ;D
I was actually very surprised when I saw how KeyShot handled the scene so well.
In the past I have used a number of other rendering engines. With all of them rendering a lamp shade without IES would be very tricky. KeyShot by far has the most straightforward approach to make it happen.
Offline DriesV
  • Global Moderator
« Reply #18 on: January 19, 2013, 12:11:59 pm »
Some more fun with lamp shades. ;D
« Last Edit: January 19, 2013, 01:54:04 pm by DriesV »
Offline Despot
  • KeyShot Beta
  • Despots rule OK
« Reply #19 on: January 19, 2013, 01:53:41 pm »
Nice Dries... love the shadow pattern
Offline Despot
  • KeyShot Beta
  • Despots rule OK
« Reply #20 on: January 19, 2013, 01:58:54 pm »
Rendered in keyShot 4 Beta - lit with just 2 Area Lights with GI turned on - the HDRI brightness was reduced dramatically, in fact its almost non-existent...
Jetfire model courtesy of Glen Southern
J
Offline DriesV
  • Global Moderator
« Reply #21 on: January 19, 2013, 02:22:39 pm »
Looking good!
Yes, the local lights are going to do some serious damage... :D
Offline DriesV
  • Global Moderator
« Reply #22 on: January 19, 2013, 02:48:23 pm »
And another pair of lamp shades, now with caustics.
« Last Edit: January 19, 2013, 03:59:19 pm by DriesV »
Offline Despot
  • KeyShot Beta
  • Despots rule OK
Mech WIP
« Reply #23 on: January 20, 2013, 05:22:55 am »
Mech WIP lit with 1 strong Area Light and 10% strength HDRI brightness...
You can now achieve well defined shadows that were extremely difficult if not impossible in KS3
Textured and materialized version to come...
J
« Last Edit: January 20, 2013, 05:25:57 am by biomechanic »
Offline Esben Oxholm
  • KeyShot Beta
    • Freelance CG Artist
« Reply #24 on: January 24, 2013, 04:43:47 am »
Caustic, Area lights and hard shadows. All the things i've been missing in the other version!
KS4 is going to be awesome!
Offline Tim
  • Jr. Member
« Reply #25 on: January 25, 2013, 03:54:16 am »
I have been out busy working on other stuff but I was very pleased to see the sneak peak.   Looks very exciting!
Offline Despot
  • KeyShot Beta
  • Despots rule OK
« Reply #26 on: January 31, 2013, 07:26:07 am »
Well get on the Beta test team then and crack out some noise free renders...
Offline Raaden
  • Newbie
« Reply #27 on: March 06, 2013, 05:10:31 pm »
Those are some impressive renderings Dries! Noise when caustics are involved isn't strange considering the amount of calculations needed. Here's an overnight render and noise is visible in the caustics (my i7 3930K could need some additional help!).
« Last Edit: March 06, 2013, 05:13:09 pm by Raaden »
Offline Morten Kristensen
  • root
  • Administrator
  • Full Member
  • Software Engineer, Luxion
« Reply #28 on: April 02, 2013, 04:10:51 pm »
Nice renderings, Dries, Raaden and biomechanic. Keep it up! :)
