Author Topic: Hydraulic Power Pack Assembly  (Read 1203 times)
Offline Scott Malcolm
  • Graphic Designer at Related Fluid Power
    • Related Fluid Power
« on: July 12, 2019, 06:46:55 am »
Another of my hydraulic product videos. Hope you enjoy!
Offline Öner
  • Full Member
  • industrial designer
Re: Hydraulic Power Pack Assembly
« Reply #1 on: July 16, 2019, 06:42:48 am »
nice job, and i have a question for you.
there is a part in the middle which has cartoon material.  how did you change the material of that part from cartoon to metal at 30th sec.?
Offline theAVator
« Reply #2 on: July 16, 2019, 07:22:06 am »
I'm not sure how he did it, but I probably would have rendered 2 versions of that segment - 1 with the toon material and 1 with the metal and then fade between them in Premiere.
Might also be able to do it right in KS with some different fade animations or something.
« Reply #3 on: July 16, 2019, 07:23:17 am »
Two similar animations, one with metal and one with toon part. Crossfade in post production.
Similar effect here:
Offline Eric Summers
    • WaterPik Home
« Reply #4 on: July 16, 2019, 07:26:38 am »
One way you could do it in KS is apply a metal material to the part, then apply the toon material as a label on the metal. Add a number fade node to the opacity of the toon material and have it fade from 1 to 0.
