Author Topic: How to do Roll-up animation?  (Read 1049 times)
Offline rskmanoj04
« on: April 10, 2019, 10:50:22 pm »
I'm a newbie and trying to do a transition animation, as in this animation (
),  of a paper rolling (spooling) after moving a little distance.
I've searched as much in the internet for a tutorial or guidance that may show something remotely similar to this.
Can anyone here please guide me to any such tutorials or suggest me how to do this kind of animation.
Thanks in Advance!
« Last Edit: April 10, 2019, 11:32:33 pm by rskmanoj04 »
Online Eugen Fetsch
    • www.camomiles.de
Re: How to do Roll-up animation?
« Reply #1 on: April 11, 2019, 12:19:42 am »
:) this is already a good one ... the only thing you need to do afterward, is to export it as Alembic file from Blender and import it in KS.
Offline rskmanoj04
« Reply #2 on: April 11, 2019, 07:24:22 am »
The problem is... I didn't make this... I have to import a big machine into KS from Solidworks & should make a similar effect to it.
Online Eric Summers
    • WaterPik Home
« Reply #3 on: April 11, 2019, 08:23:37 am »
You could create the rolling animation in blender and save it out as an .abc. Then in KeyShot import your machine from SolidWorks and import the .abc file into the same scene. Position the roll where you need it and move the animation in the timeline to the correct time point. That should get you what you're looking for.
Offline rskmanoj04
« Reply #4 on: April 11, 2019, 10:19:31 am »
Thank you all for the suggestion... will give blender a try now... :)
Never used it before  ;)
Cheers!!
Online Eric Summers
    • WaterPik Home
« Reply #5 on: April 11, 2019, 11:10:57 am »
Good luck! :)  I'm just starting with blender myself. As a full time SW user, it has taken a bit of adjustment but it seems very useful.
Offline rskmanoj04
« Reply #6 on: April 11, 2019, 11:21:55 pm »
Just for Information purposes.... (I've to inform to my superiors) Is it possible to do this in KS directly instead of using another software (blender)?
Offline Esben Oxholm
  • KeyShot Beta
    • Freelance CG Artist
« Reply #7 on: April 12, 2019, 04:03:53 am »
Nope. Deformable animations can't be made inside KeyShot without the use of third party software :)
Offline rskmanoj04
« Reply #8 on: April 12, 2019, 04:42:23 am »
Awesome.... Thank you!  :)
Offline rskmanoj04
« Reply #9 on: June 02, 2019, 04:02:31 am »
Hi! For some  unknown reasons The .abc files are not animating inside KeyShot. The models just stand still!
I also created a similar animation in Maya, same issue.  KeyShot bug?
Any Idea what could be the issue?  & How to animate it?
Online Eric Summers
    • WaterPik Home
« Reply #10 on: June 03, 2019, 02:15:13 pm »
Hmm, I can't say for sure what's going on but I'll take a guess. Keep in mind I'm still learning blender myself.
To start, I followed the tutorial and when I imported the .abc into KeyShot, I got the error "The part 'Plane_001' contains very large coordinates." Plane_001 was my spiral to roll up the plane. Then I tried exporting the .abc with the plane to be rolled up selected and in the export dialog I picked "Selected objects only". That imported into KS with only geometry errors but otherwise it worked.
So my guess would be that something happened in blender; if you move the plane does it roll up? If it does, I'm at a loss.
EDIT:
Just as I posted this I realized I forgot to ask, did you keyframe the movement of the plane?
« Last Edit: June 03, 2019, 02:16:51 pm by Eric Summers »
Online Eugen Fetsch
    • www.camomiles.de
« Reply #11 on: June 04, 2019, 01:03:51 am »
For Alembic export in Blender check "Apply Subsurf" and uncheck "Normals". In KS check "Deformable Meshes" in the import prompt. There will be still an issue with the smooth shading of the plane in KS. This is a KS issue, I've double checked it in Modo - no issues there.
Online Eric Summers
    • WaterPik Home
« Reply #12 on: June 04, 2019, 06:36:48 am »
I had been using the default export settings for Alembic, so that's good to know. Thanks!
Offline rskmanoj04
« Reply #13 on: June 21, 2019, 06:51:31 am »
Applying Subsurf did the trick! Thank you!
Uncheck 'Normals' - In KeyShot while importing? I didn't see any Normals in Blender
Offline rskmanoj04
« Reply #14 on: June 21, 2019, 06:57:06 am »
.abc file when imported in KeyShot is creating a path of its own and moving. How to stop it?
