Author Topic: Noise in acrylic during animation!  (Read 1062 times)
Offline Poog
  • Newbie
« on: February 19, 2019, 10:08:00 am »
Hi folks, cant share TOO much info due to the project being an NDA (will share as much as I can!) but when I animation this product, theres a lot of noise in the acryllic sections mainly. Now this looks fine as a still, but when animating you can see the noise like crazy. I can't get into keyshot at the moment but I'm using the default studio set up product mode, with caustics turned on and ray bounces are at about 10 last I checked. The canvas material looks great up top, and this is the only area with severe enough noise.
Samples are at about 250, and I suspect we need to bump samples up to around 500+ to resolve this but we're hoping to keep it time efficient if possible, and 500 samples might be a bit much on our current machine. I attempted samples on individual materials but didnt see the option on keyshot 8 (maybe I'm blind.)  So, thoughts? Is it the sampling, or perhaps an issue with the default lights?
Thanks in advance for any help!
Offline Eric Summers
  • Sr. Member
  • CAD Specialist II, Water Pik, Inc.
    • WaterPik Home
Re: Noise in acrylic during animation!
« Reply #1 on: February 19, 2019, 02:44:59 pm »
Try enabling Global Illumination if you don't have it on and change from Product to Interior Mode.
Offline bdesign
« Reply #2 on: February 19, 2019, 02:56:25 pm »
Also, make sure you're rendering with Max Samples, not Max Time under the render options; this will keep the samples/noise constant for each frame and prevent flickering.
Cheers,
Eric
Offline Esben Oxholm
  • KeyShot Beta
    • Freelance CG Artist
« Reply #3 on: February 20, 2019, 05:18:35 am »
Is the caustics crucial for the wanted look of you rendering?
Otherwise I'd suggest to turn that off and I think what is causing the problem. Caustics definitely needs a lot of samples to be super smooth (Espcially for animation)
Offline Poog
  • Newbie
« Reply #4 on: March 04, 2019, 10:21:16 am »
Late answer, but doing it anyway in case someone else has a similar issue. This right here solved it.
