Author Topic: keyshot8 animation axis problem  (Read 248 times)
Offline PeterSwift
  • Full Member
« on: January 22, 2019, 05:39:02 am »
A new animation project= finding new animation bugs.
Or maybe it's just be that just don't understand the program correctly.
Here a test.
Dark cube has a translation.  Cylinder, has a 360 rotation around the dark cub.
Blue cube is just there to show the original cube position.
I can't make the cylinder follow and rotate around the dark cube. Should be so basic.
« Last Edit: January 22, 2019, 05:41:23 am by PeterSwift »
Offline Esben Oxholm
  • KeyShot Beta
    • Freelance CG Artist
Re: keyshot8 animation axis problem
« Reply #1 on: January 22, 2019, 06:05:02 am »
Hi Peter.
Have a look at the attached file.
Make sure to nest the cylinder inside the moving cube in the scene tree.
Hope it helps!
Offline PeterSwift
  • Full Member
« Reply #2 on: January 24, 2019, 01:06:37 am »
Yeah I finally made it work.
But there must be some kind of bugs. Becouse now When i try to rotate an object I have been moving around a bit, translations and rotations.   Now when I add a new rotation, so it should rotate around it self (spinn) . I can't make it do it.  It follows some axis somewhere else. It' dont help if i use a new object and select that as an axis.
Very confusing.
Thanks for the help though.
