Author Topic: Olive drab color...  (Read 5929 times)
Offline berzer
  • Newbie
Olive drab color...
« on: August 24, 2011, 11:36:50 pm »
I'm trying to make a new material in an old military style - olive drab color.
But everything what I make is shiny, reflective etc :(
How to make material similar to this one one the picture?
Can someone help me with this?
  • Guest
Re: Olive drab color...
« Reply #1 on: August 25, 2011, 05:07:33 am »
Use a plastic material?
elliasp
  • Guest
« Reply #2 on: August 25, 2011, 05:24:19 am »
Try "flat" material (it's on the material list editing menu).
Offline Chad Holton
    • Portfolio
« Reply #3 on: August 25, 2011, 05:44:11 am »
Hi berzer,
You can make this color with muliple material types. It's all about personal preference. I would use Diffuse as the material type, but if it's too "flat" try the advanced material type and play with the settings there. Let us know if you need more help!
Chad
Offline berzer
  • Newbie
« Reply #4 on: August 25, 2011, 05:55:31 am »
I know. I was trying to do that - effect?  :-\
This one is with "flat" metarial...  :-[
« Last Edit: August 25, 2011, 06:02:20 am by berzer »
  • Guest
« Reply #5 on: August 25, 2011, 06:01:20 am »
@Chad Holton - no need for the advanced material
To edit the material double click on it once it is applied. Change the specular color to black or a dark grey so you get just a tiny bit of reflection, and then add some roughness if needed.
Offline rkulshrestha
  • Full Member
« Reply #6 on: August 25, 2011, 08:38:53 am »
Use Color Pixie, a free download from the Net. This will give you the exact RGB/HTML/Hue readings for anything on your screen. Once you have that you can play with other settings like IOr etc
Shivani
