Author Topic: [RESOLVED] Keyshot 8 texture sync  (Read 1218 times)
Offline RAF985
« on: November 28, 2018, 01:55:56 pm »
Since i've updated to keyshot 8 texture sync is not working anymore. Anyone with same issue? There's something new about that I missed with this version?
thanks
« Last Edit: April 11, 2019, 04:36:19 pm by Francisco »
Offline Francisco
  • KeyShot Beta
Re: Keyshot 8 texture sync
« Reply #1 on: March 28, 2019, 08:13:17 am »
Hello RAF985,
Can I ask what you mean by Texture sync? Are you opening files that were created in KeyShot 7 in KeyShot 8 and the texture you were using are no longer showing up? Would it be possible to open your file in KeyShot 7 and then save it as a KSP file? After you do that can you open it and save the resources to your KeyShot 8 library and let me know if you still get the same error?
thanks
« Reply #2 on: March 28, 2019, 02:08:53 pm »
Might mean the sync function between textures in a material that connect the scale and mapping? I notice that the sync gets broken if a node is placed between the texture and the material , that texture will no longer be synced to the textures that are directly connected to the material.
Offline Francisco
  • KeyShot Beta
« Reply #3 on: March 28, 2019, 04:11:22 pm »
Hello mattjgerard,
Thank you for that mattjgerad, for pointing that out to me.
Raf985, would you be able to send the file that you are having issues with to [email protected] so that we can try to reproduce the issue you are having?
If the file is over 20 megs you would need to send it to us with https://keyshot.wetransfer.com/ as it would allow you to send files up to 2 gigs.
Offline Bruno F
  • KeyShot Support
  • Full Member
Re: [RESOLVED] Keyshot 8 texture sync
« Reply #4 on: April 17, 2019, 03:37:25 pm »
There have been no replies to this post for more than two weeks, therefore, it has been locked.
If you still need help please open a new post.
Post closed by Luxion Support Team[/li][/list]
