Author Topic: Subsurface texture, braid inside tube  (Read 1208 times)
Offline bradlar90
« on: August 16, 2018, 03:00:45 pm »
I need to spend this weekend creating a somewhat complex render (at least it is for me) but there's one component that I'm not sure how I'm going to tackle.
It's a transparent PVC tube that has reinforcing fibres embedded in a kind of braid pattern. I'm guessing I will need to create a repeating pattern, but how will I get it to line up so that there are no obvious seams, and how can I make it appear below the surface?
If anyone has any thoughts or advice, or could point me in the right direction of which techniques I should investigate that would be very much appreciated. Cheers
Offline Öner
  • Full Member
  • industrial designer
Re: Subsurface texture, braid inside tube
« Reply #1 on: August 16, 2018, 10:51:18 pm »
i think you need to model this pvc tube within 2 layers in it.
1) Tube layer for pvc, you can look at the material that i added as attachment.
2) Middle layer for fibres,
i tried to make it, you can download the materials for that.
Of course you may need to prepare your texture on PS, specially for thickness of the fibres because of i used the mesh rectangular texture on the KS as opacity map and the thickness has done as you see.
« Last Edit: August 16, 2018, 11:01:11 pm by Öner »
