Author Topic: Zbrush Plugin Model UVs dont carry over to Keyshot  (Read 1250 times)
Offline MiKL
« on: July 30, 2018, 02:50:52 pm »
When I import a fbx or .obj with UVs to Zbrush and send to keyshot renderer the UV coordinates dont work in Keyshot 7 Pro for Zbrush I have had this problem also with Keyshot 6 Pro before upgrading to Keyshot 7 for Zbrush Plugin Model UVs dont carry over to Keyshot. I have tried the UV legacy settings and the other UV setting but the only way to get my Substance Painter textures to carry over is the choose Box or Sperical. I have noticed that there are other users of Keyshot for Zbrush that have the same issue getting UVd models to work in Substance Painter textures or any other The Foundry Mari textures.
Offline MiKL
Re: Zbrush Plugin Model UVs dont carry over to Keyshot
« Reply #1 on: July 30, 2018, 04:39:04 pm »
I discovered a fix for this issue it turns out Zbrush flips the UV coordinates on the Y axis so all you I needed to do is import the textures in Photoshop and flip them vertically now the Substance Painter textures are importing correctly into Keyshot with the Keyshot bridge also the Substance normal maps need to be flipped on the green channel.
