Author Topic: How to fix camera switch event?  (Read 422 times)
Offline Erebas
« on: June 05, 2018, 12:10:31 am »
Hi Keyshot,
I'm trying to create one solid animation with camera switch events, and cut up these into separate clips in Premiere Pro. However, after the third camera switch event it ignores the cameras prior to it. Here's what I've been doing:
1. Begin the animation with camera 1. Other camera animations play.
2. Create a switch event "from camera 1" "to camera 2".
3. That works fine. Create a switch event "from camera 2" "to camera 3".
4. Also fine. Create the next switch event in the cycle. Now while I should have a linear progression of cameras, instead the entire animation takes place from the perspective of camera 3, and now only the most recent camera switch (from camera 3 to 4) functions correctly.
Also, if I delete or hide the most recent switch event, everything returns to normal.
Could someone explain how to fix this?
I'm using Keyshot 7.1 pro
Offline Lei
  • Product Designer turned Animator
Re: How to fix camera switch event?
« Reply #1 on: June 14, 2018, 05:38:42 am »
Pretty sure you had your camera 3 selected when rendering or previewing?
Select camera 1 if you havent done so.
