Author Topic: Curvature outlines every single polygon  (Read 1391 times)
Offline petz_e
  • Newbie
« on: May 25, 2018, 02:44:54 am »
I am having problems with the curvature map. Here is a screenshot of a scene, where only the curvature map information is visible. You can clearly see tiny horizontal and vertical lines resulting from 'outlining' every face. I tried playing with the cutoff and radius settings but I can't manage to reduce this effect.
This is the default ZBrush model (subdivided to 1 million polys) with no UVs. But this also happens with every other model.
Is this a 'known' behavior? What am I doing wrong?
« Last Edit: May 25, 2018, 11:53:16 pm by petz_e »
Offline DMerz III
  • KeyShot Beta
  • David Merz the Third
    • MerzTheThird
Re: Curvature outlines every single polygon
« Reply #1 on: May 26, 2018, 10:16:34 am »
 :o whoa, strangely enough, that is a cool effect, but obviously, not what you intended.
Anytime I see something this odd, my first instinct is to Geometry Editor > Normals> Recalculate Normals (make sure you actually hit the recalculate normals button and hit okay before anything takes effect).
That's all I got.
Hope something gets resolved.
Offline cjwidd
  • Sr. Member
    • ArtStation
« Reply #2 on: June 11, 2018, 11:44:29 am »
I had this same problem with decimated Zbrush sculpts when I first started using Keyshot.
