Author Topic: Randomized Texture Mapping  (Read 2693 times)
Offline hnax
« on: May 24, 2018, 08:39:51 pm »
related topic https://www.keyshot.com/forum/index.php?topic=20605.0
The product lack a way of repeating a texture pattern randomly. This is a very common problem when tiling the same texture over a big surface. Folks have been asking for this for a while. It's almost a need in every architecture/interior design rendering. Keyshot should put this high on their new features list ask if they are planning to expand their audience from the product rendering community into the architecture/interior design community.
Re: Randomized Texture Mapping
« Reply #1 on: May 25, 2018, 06:13:09 am »
+1
Offline aaron f
« Reply #2 on: May 25, 2018, 09:11:27 am »
+1
pretty pretty please!
Online scanner
« Reply #3 on: May 26, 2018, 01:22:03 am »
I support also.
Offline DMerz III
  • KeyShot Beta
  • David Merz the Third
    • MerzTheThird
« Reply #4 on: May 26, 2018, 10:08:41 am »
While I think having a "random" node in the material editor for things like this would be cool, there are some things you can do right now in 7 that will help alleviate this problem.
Using several labels that are mapped differently and compiling them with a "color composite" node will start to break up the patterning you see.
Also, you can use procedural textures such as the noise in Keyshot to break up the patterning as well, lots of current tools already in keyshot at your disposal.
« Last Edit: May 26, 2018, 10:31:41 am by DMerz III »
Online INNEO_MWo
« Reply #5 on: May 27, 2018, 10:25:23 am »
David - you're a genius - thank you for the hint.
Related to this thread (https://www.keyshot.com/forum/index.php?topic=20605.0) I attached a solution with a mesh texture node (procedural) to randomize a wood texture (file).
« Last Edit: May 27, 2018, 10:30:00 am by MWo »
Offline DMerz III
  • KeyShot Beta
    • MerzTheThird
« Reply #6 on: May 29, 2018, 12:41:53 pm »
Haha! Thanks, you're too kind. That is a great breakdown you did, thanks for taking the time to go through that, I am always so quick to write out what I think a solution might be, but do very little to actually demonstrate the solution, so it is nice that you took the time to do so; very helpful for others!
Offline Furniture_Guy
  • Full Member
    • Virco Educational Furniture
« Reply #7 on: May 30, 2018, 07:55:12 am »
David - Damn, you are a genius. I never thought of that...
Many, many thanks!
Perry (Furniture_Guy)
Offline Søren
  • Developer
  • Jr. Member
  • KeyShot Developer
    • KeyShot
« Reply #8 on: June 01, 2018, 05:19:13 am »
Thank you for your input for this. We have seen this request before and it could definitely make sense (no promises on when).
Adding to David's suggestion there is a little-known feature in KeyShot 7 that can help as well. The mesh-node can be used to control the UV mapping of a texture map. By using jitter, distortion and the color composite node with alpha maps, I think you can break up repetitions to some extent. It is not as powerful as a fully randomized per-part texture map node, but it may help you in certain cases.
I am sure a more artistic person than myself can get more out of it :).
/Søren
« Last Edit: June 01, 2018, 05:21:04 am by Søren »
Offline DMerz III
  • KeyShot Beta
    • MerzTheThird
« Reply #9 on: June 01, 2018, 08:48:56 am »
 :) NICE.
Thanks Soren, that is a breakdown.
