Author Topic: Combining Two Opacity Maps  (Read 2894 times)
Offline Jikkk
  • Jr. Member
« on: April 29, 2018, 02:25:27 am »
Hey, everybody!
How to combine two (or more) opacity maps? I've been experimenting with the Color Composite node with all types of Blend Modes but nothing worked.
Thanks!
Offline INNEO_MWo
Re: Combining Two Opacity Maps
« Reply #1 on: April 29, 2018, 09:30:17 pm »
Hello Jikkk.
I guess you’re on the right track.
What are the resources for the composite node?
You can also combine several procedural textures.
Or use a color to number node between the composite node and the opacity channel.
If you tell us which version of KeyShot do you use, I can post an example.
Offline Jikkk
  • Jr. Member
« Reply #2 on: April 30, 2018, 01:49:28 pm »
Hey!
My inputs are two Mesh textures with different setting (Circular and rectangular). I am using KeyShot Pro 7.2.
Offline INNEO_MWo
« Reply #3 on: May 01, 2018, 02:53:11 am »
Yeah! Does it work as you expected?
Offline Esben Oxholm
  • KeyShot Beta
    • Freelance CG Artist
« Reply #4 on: May 01, 2018, 03:11:36 am »
Hi Jikkk.
I just tried this out and can see that it at first behaves a bit differently than if you've used bitmaps.
I found that if you in each mesh texture change the alpha mode to 'opaque', then they will blend like regular bitmaps.
Let me know if it works for you.
Cheers,
Offline Jikkk
  • Jr. Member
« Reply #5 on: May 01, 2018, 12:13:35 pm »
Thanks Esben..
It now works like it should be. You're a Keyshot master!!!!  :)
Offline Jikkk
  • Jr. Member
« Reply #6 on: May 01, 2018, 12:14:57 pm »
Hey Marco. Esben tip works. Thanks anyway!
  • KeyShot Beta
« Reply #7 on: May 01, 2018, 11:03:35 pm »
Thanks Esben..
Great, good to hear!
Offline Finema
  • Designer
    • Delavallade Design
« Reply #8 on: May 01, 2018, 11:12:19 pm »
Thanks Esben for this tip  ;)
Offline INNEO_MWo
« Reply #9 on: May 02, 2018, 08:16:53 am »
Glad to see, that this works.
It is a lil different if you write on a mobile phone or have an access to a system to test.
Esben's doin' right!!!
