Author Topic: Load different fra-files  (Read 3166 times)
Offline umueglitz
« on: December 01, 2017, 08:33:06 am »
Hallo,
I want to animate a more complex process. Therefore I want to have different "sub"-animations, which I want to define in Creo and assemble together in Keyshot to the whole animation. Unfortunately I didn't find an option to upload different fra-files. Does somebody know a solution for that or is this attempt not supported?
Thanks in advance for your support.
Offline INNEO_MWo
Re: Load different fra-files
« Reply #1 on: December 02, 2017, 12:56:58 am »
You can reload the assembly in an extra model set with another fra input. Now you can switch between different sets and render several animations that have to be composed in post.
Or you can use the creo plugin and export several bip files with different fra files embedded. These can be used in a KeyShot scene with model sets.
Hope that helps to find the right track. I never tried these but it should work.
If I don't forget I'll give it a try next week.
Have a nice weekend.
