Author Topic: Keyshot file keeps growing, up to 8gb in size now!  (Read 1374 times)
Offline eobet
  • Newbie
« on: September 21, 2017, 04:40:37 am »
I work with large CAD models, so my files are big, but I noticed something which feels wrong a few times now. First in Keyshot 6, then Keyshot 7:
If I have a model set, and then delete it, the keyshot file still retains an increased file size.
If I import an additional model and then delete it, the keyshot file also still retains an increased file size.
Why is this?
Case in point:
I just imported a STL file into my Keyshot file that seemed to screw up the lighting. So I deleted all parts except one tiny one that had obvious lighting issues and made a .KSP file out of it. The result was a single .HDZ 15mb file and a freaking 4.6gb .BIP file for basically a small metal bracket that's got the default aluminium rough material on it. What bug is in play here?
« Last Edit: September 21, 2017, 05:15:29 am by eobet »
Offline mattjgerard
Re: Keyshot file keeps growing, up to 8gb in size now!
« Reply #1 on: September 21, 2017, 06:59:29 am »
I've had this happen as well, its like some sort of hidden undo cache isn't emptied until a certain point. Even doing a "Save As..." didn't work. I had to close the project, open a different project, then reopen the original project to get the file size to reflect the fact that I deleted 90% of the geometry. And this was all when I was trying to bundle a file for sending into support !!!!
In lots of the adobe products, there is a "Purge Cache" function, maybe we can have something like that? I understand the the undo functions can sometimes hang on to stuff a little longer than intended too.
  • Guest
« Reply #2 on: September 21, 2017, 09:38:38 am »
This issue is addressed in KeyShot 7.1. The workaround in prior versions was to open the the scene, and save it again.
Offline eobet
  • Newbie
« Reply #3 on: October 16, 2017, 04:06:49 am »
I don't find it to be adressed at all. I just deleted all my scene/model sets save one, and deleted 90% of the geometry in my file and reimported some new and optimized replacement geometry.
Last file with an "OK" size was 1.5gb. Most recent Keyshot 7.1 save: 7.5gb.
So, around july/august this year, things were "fine", but now (october) they're not again?
« Last Edit: October 16, 2017, 04:15:47 am by eobet »
