Author Topic: problem importing from solidworks  (Read 7331 times)
Justin A and 1 Guest are viewing this topic.
Offline a737
« on: February 28, 2011, 01:04:14 pm »
Hi, I have assigned different colours in the solidwork file so as to differnciate the different materials, so when I import the Step file in the keyshot it recognizes the object with separeted surfaces. I always do it this way and it usually works. But now, when I import the step file it doesn´t recognize the different surfaces, it is just one colour so I can´t assign the different materials in the keyshot.
I hope I was clear enough.... does anybody have a usefull tip?
thanks!
Re: problem importing from solidworks
« Reply #1 on: February 28, 2011, 01:37:29 pm »
Why are you exporting to STEP?
Offline Speedster
« Reply #2 on: February 28, 2011, 06:34:03 pm »
I'll add my experience with 2.2.42x64.  When I prep in SolidWorks I have often used configurations for multiples of the same part that I want to map differently in KeyShot.  Always has worked fine.  Now, however, the SW model imports into KS with a whole different mapping than I had set up.  I now have to create descrete parts as a "save-as" under different names to get them to work.  Real pain, and added about 2 hours to the setup.
The attached images illustrate.  First image is a Solidworks screenshot.  Second is a KS screenshot immediately after importing.  Last image is what I had to create for my client.
Offline a737
« Reply #3 on: March 01, 2011, 12:45:05 am »
Thanks Bill G!
I usually do the same, give a different colour to the object's part in which I want to have different material in Keyshot. I "save as" Step, and in Keyshot I import it.  In what format do you save it?
thanks!
Offline a737
« Reply #4 on: March 01, 2011, 04:02:56 am »
This is a problem I am having with some bodies. I have attached a snapshot from solidworks ( in grey) and a snapshot from Keyshot ( in orange) and you will see how the body gets faceted and broken whene it was smoother in the solidworks file.
Is it possible to correct this?
Offline JeffM
« Reply #5 on: March 01, 2011, 06:20:48 pm »
Are you changing the tessellation quality in SW?
Perhaps you're changing it in the assembly, and not enabling the option to apply those changes to the part level.
« Reply #6 on: March 02, 2011, 07:04:08 am »
Bill - I am not sure I fully understand. Can you contact me directly so we can take a look at what's going on here?
Thomas
