Author Topic: How to make double sided Materials?  (Read 3722 times)
Offline Renata
« on: May 23, 2017, 05:46:06 pm »
Hello everyone,
I am having trouble creating double sided/2faced material... picture one simple plane with one side red and the other green, how can i create a material to do that without having to create another plane?
Offline NM-92
  • KeyShot Beta
    • Behance
Re: How to make double sided Materials?
« Reply #1 on: May 23, 2017, 07:04:40 pm »
Hello. You can easily do that using the mat graph. I can't remember the name of the node in English though but i'm attaching some images ! I think it's something like "backface mask", under utilities in the graph. Let me know if you need anything.
Offline Renata
« Reply #2 on: May 24, 2017, 06:38:06 am »
Hi NM-92, Thanks for the reply ....But what if it was a material not just a color? one plane with different materials (with different textures) on each side? the problem is it is sort of a fabric on a sphere so applying it as a label with normal projection would result in bleeding no matter the depth. Any idea how to approach this?
Offline MWo
« Reply #3 on: May 24, 2017, 08:30:01 am »
Hello Renata.
The solution from Nico works for different color and materials. I attached a sample file. You can work with the material graph to change the side between "metal" and "fabric" in the "color to number"-node when replacing the values "output from" and "output to".
(the "backside surface mask"-node is available when activating "experimental features" in the preferences)
The mapping problem can be fixed with the UV mapping option. (I guess that the fabric mesh contain UV coordinates.
Hope that helps
Offline Renata
« Reply #4 on: May 24, 2017, 09:50:38 am »
Perfect! Fixes my problem
Thanks Marco appreciate it.
Offline MWo
« Reply #5 on: May 24, 2017, 10:38:11 am »
I share your thank you with Nico.
Glad to help.
