Author Topic: 2.2 is slower?  (Read 4654 times)
Offline andy.engelkemier
2.2 is slower?
« on: February 07, 2011, 05:58:15 am »
I was getting 16FPS on the benchmark scene, now only 14.
Offline PhilippeV8
Re: 2.2 is slower?
« Reply #1 on: February 07, 2011, 06:51:50 am »
I had 20-21-ish .. got 18-19 now ...
Re: 2.2 is slower?
« Reply #2 on: February 07, 2011, 07:40:44 am »
Are you both using the camera.bip file?
Re: 2.2 is slower?
« Reply #3 on: February 07, 2011, 08:01:53 am »
Yes, I am.
Although, if you remember, my speeds seem pretty slow for the specs of our machines anyway. Most people seem to be a Lot faster.
Re: 2.2 is slower?
« Reply #4 on: February 07, 2011, 08:25:19 am »
I just ran a back to back test of KeyShot 2.1 vs. 2.2 on my MacBook Pro, and I am getting 14.5 FPS with both builds.
Re: 2.2 is slower?
« Reply #5 on: February 07, 2011, 10:32:57 am »
could have something to do with hyperthreading or something like that then? I'm not really sure what's changed, but it's definitely a bit slower on our end.
We definitely dropped a couple (much needed) frames per second.
Also, not sure if it makes a difference, but this is Windows 7 Pro x64.
Offline JeffM
Re: 2.2 is slower?
« Reply #6 on: February 07, 2011, 10:52:19 am »
Back to back I'm getting the exact same performance.
You could also install 2.1 to an alternate program folders location and do a back to back comparison if you would like.
Re: 2.2 is slower?
« Reply #7 on: February 07, 2011, 12:01:07 pm »
strange, not I'm getting 14.2 in both.
Also, a bit annoying, but I'm sure not too many have the same issue. I had floating using the bin folder, then the node locked using a renamed binfolder. When you run the node locked update it doesn't update the correct install.
I just reinstalled both and now it's fine. I'll just have to remember that in the future. One thing easy that might solve that though would be to actually have the floating install to a different location so you could update each without having to manually change things around.
Re: 2.2 is slower?
« Reply #8 on: February 07, 2011, 12:52:21 pm »
With KeyShot 2 you can actually install NL and FL into the same folder. Run the NL installer first, then the FL installer. You have both executables in the same bin folder. Works great.
Also, as far performance goes, my MacBook Pro has a Core2Duo chip. No HyperThreading.
Offline JeffM
Re: 2.2 is slower?
« Reply #9 on: February 07, 2011, 01:19:34 pm »
Andy, are you getting any less usage of your cores in the task manager in 2.2?
Re: 2.2 is slower?
« Reply #10 on: February 07, 2011, 02:07:00 pm »
As far as I can tell it's the same. It seems really close to 100% on all of them. Of course they bounce up and down as far as maybe 80% but that's pretty ordinary with most all renderings where you need to keep moving the mouse around and have just a few resources free to continue working in "real-time"
I guess we just have some old machines. They do ok, but definitely need to be updated. They still seem to be pretty competitive in Vray is all. That's what we end up comparing with for the most part.
