Author Topic: KeyShot crashes when using "Material Templates" -> "Add Item"  (Read 1920 times)
Offline Tom Junker
Hey,
we just got our KeyShot and i was playing around with some stuff and got an nasty bug already. I would like to use the material template system since i usually assign most materials in CREO to my models/parts. However, every time i try "Add Item" the program freezes and shuts down.
I checked https://www.designassist.info/cadsoftwaredirect/Knowledgebase/Article/View/75/0/keyshot-crashing and removed read only. Since all PCs are administrated by our helpdesk, i can't do much, but changed enable_gpu from true to false, but didn't either. Also, Experimental Features are disabled.
Anything i could try before i ask our helpdesk to download and install Visual C++ and .NET?
Offline Chad Holton
    • Portfolio
Re: KeyShot crashes when using "Material Templates" -> "Add Item"
« Reply #1 on: October 27, 2016, 06:31:22 am »
Hi Tom,
I know you mentioned that you just got KeyShot but can you confirm the version you're using (e.g. 5.1.234)?  You can find this under Help>About.
You can probably enable your GPU again, as this would cause a crash at startup most likely. As for the issue, I tried to recreate with a Creo file but wasn't able to.  See if it happens on one of the stock scenes that come with KeyShot and let us know what you find out.
Chad
Offline Tom Junker
« Reply #2 on: October 27, 2016, 06:53:04 am »
Hi Chad,
sorry for not mentioning it. It is 6.2.105
Cheers, Tom
Offline Will Gibbons
  • willgibbons.com
    • My Website
« Reply #3 on: October 27, 2016, 07:28:53 am »
I just gave it a go and didn't have any issues with crashing. I was able to add, create, delete and use material templates.
Offline Rex
  • Global Moderator
« Reply #4 on: October 27, 2016, 09:33:08 am »
I am able to cause a crash by deleting the default entry. Perhaps that is related. I will pass along to development.
Offline Tom Junker
« Reply #5 on: October 28, 2016, 12:26:29 am »
Hey Rex,
thanks for the reply. Now i see the problem. I was trying to add an item into an non existing template. When i add a template and then the item, it is working. Tho, still a bug isn't it?
Cheers, Tom
