Author Topic: Importing Geometry After Creating a sceneset  (Read 1333 times)
Offline 1fastlearner
« on: October 06, 2016, 12:11:11 pm »
Is it possible to import an updated piece of geometry and apply it to scene sets I have already created?
The scene sets I created, have other parts which I have moved from a different position than the default scene.
When I import the updated piece of Geometry it is put in the default scene set. Can I move that geometry to the other scene sets without having to go back and create a new scene set?
Re: Importing Geometry After Creating a sceneset
« Reply #1 on: October 06, 2016, 12:27:47 pm »
Yes you can copy the geometry to the scene set - simply right click onto the object in the scene tree and select "copy to scene set", and select the appropriate scene set.
« Reply #2 on: October 07, 2016, 11:39:44 am »
I just tried it and it worked. Thanks
What I also noticed too was that, 1) the geometry needed to then be correctly ordered in the scene hierarchy within the scene tree and 2) You then needed to re-scale and re coordinate the geometry.
In my case I had to do this because I wanted this particular geometry to match the position of its predecessor
