Author Topic: Interior Lighting - IES Cones  (Read 2589 times)
Offline sir.orange
  • Newbie
« on: September 07, 2016, 12:41:39 am »
Hi there,
I m mostly rendering interior scenes. I do very hard to adjust the cones of my spot lights as there is just a big mess of orange cones. The mess makes it nearly impossible to see the cone moving when I adjust positions and angles.
Is there a solution I just don t know not to lose track? Turning off all other objects is not a solution as i need other objects refering to the IES cone.
...Highlighting the complete cone would be nice!?
Offline LayC42
  • Sr. Member
  • mostly harmless
Re: Interior Lighting - IES Cones
« Reply #1 on: September 07, 2016, 01:10:20 am »
hmm, this should be improved. Maybe you can turn off the cones in live render window (L key) and move the selected light sources in the geometry view?
hope that helps a bit
Offline sir.orange
  • Newbie
« Reply #2 on: September 07, 2016, 03:48:36 am »
what do you mean with geometry view?
I turn on/off the cones and select the ones to be adjusted in the scene tree, so I always need to de-select the cones surrounding. very time consuming  :-[
Offline MWo
« Reply #3 on: September 07, 2016, 04:08:42 am »
The geometry view is capable to select the light source. The screenshot should explain itself.
Offline sir.orange
  • Newbie
« Reply #4 on: September 09, 2016, 02:47:26 am »
thank you, this is really helpful and a good solution
