Author Topic: KeyShot Newsletter - August 2016  (Read 1247 times)
Offline Josh Mings
  • Global Moderator
    • keyshot.com
« on: August 25, 2016, 06:06:10 am »
In this issue:  Product Render Workflow, Material Samples, Shift Lens and More.
KeyShot Webinar
** Product Rendering Workflow in KeyShot
Thursday, September 1st, 2016 - 10:00 - 11:00 AM PDT
From setting up your scene to creating a compelling image, we’ll work through a scene from start to finish and cover a variety of topics on the way. Sign up now as space is limited! In this webinar:
* Model import
* Assigning materials
* Setting up the scene
* Lighting Environment
* Q & A
Register Here  › https://attendee.gotowebinar.com/register/5996078186989726724
** Customer Spotlight: GE Healthcare
GE Healthcare uses their ingenuity in scientific medical technology to create medical devices for every need.  Learn how they use KeyShot throughout each phase of the design process to communicate their design vision.
Read More  › https://www.keyshot.com/ge-healthcare
** Artist Feature: Matt Thorup
Matt Thorup is a Senior Character Artist who has brought beloved characters and interesting creatures to life with a style that's as detailed as it is playful. Read why he uses KeyShot in his workflow.
Read More  › https://www.keyshot.com/matt-thorup/
** Occlusion Passes in KeyShot
Learn how occlusion works in KeyShot, how to create occlusion passes and the flexibility it provides when you need darker shadows in specific areas.
Read More  › https://www.keyshot.com/2016/create-occlusion-passes-keyshot/
** Using Shift Lens in KeyShot
Learn about working with different types of perspective and how you can acheive perfectly straight verticals with the Shift Lens Setting in KeyShot.
Read More  › https://www.keyshot.com/2016/use-shift-lens-setting-keyshot/
** KeyShot Quick Tip: Output Render Samples
In this KeyShot Quick Tip, we look at how to calculate the amount of samples needed to render your scene by using the Heads-Up display and adjusting the amount of samples needed.
Watch Now  › https://www.keyshot.com/resources/learning/quick-tips/
** Metal Material Mastery Recap
Catch the recap of out metal material mastery webinar, plus grab the presentations and the downloads.
Learn More  › https://www.keyshot.com/resources/downloads/scenes/
** Upcoming Events
View Dates  › https://www.keyshot.com/events/
View newsletter online here
