Author Topic: Script for multiple colorways help  (Read 8968 times)
  • Guest
Re: Script for multiple colorways help
« Reply #15 on: May 26, 2016, 01:00:05 pm »
Looking the camera or not makes no difference. Lock the camera, change the resolution including aspect ratio, and notice what's happening.
Offline DriesV
  • Global Moderator
« Reply #16 on: May 26, 2016, 02:15:03 pm »
Interesting scene. The realtime image temporarily compresses/elongates as you change the aspect ratio. This reflects in the rendering through the script, as you specify a different aspect ratio, so that the red parts appear to not fit.
So the script is actully rendering the 'stretched state'. I think this is a bug. I will investigate.
I didn't see this issue in my own testing, but this scene clearly shows it.
« Last Edit: May 26, 2016, 02:17:13 pm by DriesV »
Offline maf1909
  • Newbie
« Reply #17 on: May 26, 2016, 02:19:39 pm »
With any luck, I'll be able to use this to put a final product on our website.  This product is just a start of what we have in mind!
Offline DriesV
  • Global Moderator
« Reply #18 on: May 26, 2016, 02:24:10 pm »
For now, just make sure you have the correct aspect ratio in realtime. Then the image shouldn't stretch.
I will keep you updated.
Offline maf1909
  • Newbie
« Reply #19 on: May 27, 2016, 07:29:22 am »
how would this need to be changed to keep labels when it changes materials?
Offline DriesV
  • Global Moderator
« Reply #20 on: May 27, 2016, 10:11:08 am »
This is currently not possible, as you can't access the material properties through scripting. A label is a part of the material.
Material access is planned for a future version of KeyShot.
Can you put the shared label on a separate piece of gometry than the base material? E.g. with an opacity map?
Offline DriesV
  • Global Moderator
« Reply #21 on: June 07, 2016, 08:22:25 am »
@ maf1909:
Btw, the issue you saw with stretching of images (due to setting a different aspect ratio through scripting) will be solved in KeyShot 6.2, which is to be released very soon.
There was a bug for setting the resolution when using an orthographic camera (as you did).
Offline maf1909
  • Newbie
« Reply #22 on: June 07, 2016, 08:35:48 am »
@ maf1909:
awesome, good to hear!
Is it possible to make this script render to photoshop with layers?  It's looking like that's the way I'm going to have to do these images.
Offline DriesV
  • Global Moderator
« Reply #23 on: June 07, 2016, 12:23:20 pm »
It is currently not possible to render to PSD with scripting.
You can render all passes and render layers to images though.
Offline maf1909
  • Newbie
« Reply #24 on: July 15, 2016, 01:20:52 pm »
will it be possible to render to PSD with scripting in a future update?  That would save me a HUGE amount of time considering I have 116 materials to drag over, type in the name, and add to queue.
