Author Topic: Importing from Creo 3.0 to KS 6.1 - nothing happening?  (Read 2815 times)
Offline tfboy
« on: February 25, 2016, 07:09:45 am »
Having just upgraded to KS6.1, I no longer seem to get the import working with Creo (version 3.0 build M020).
I have installed the updated plugin for Creo 3, set up the variables, I have the protkdat variable configured, the render buttons appear in Creo.
When I click on Render, it loads up KS, but that's it, it doesn't import the model.
Importing Creo assemblies manually into KS works fine, but of course I lose the live linking.
Any ideas? I don't know whether the problem is more with Creo, the plugin or KS.
Offline LayC42
  • mostly harmless
Re: Importing from Creo 3.0 to KS 6.1 - nothing happening?
« Reply #1 on: February 25, 2016, 08:56:12 am »
There can be (perhaps) a registration issue. Maybe a re-installation of KS6 would help. Otherwise the plugin enables the export to a bip-file. So you can re-import the bip-file and use "update geometry" - it's like live linking (manually)
Maybe that helps?!
