Author Topic: Script for rendering deformable meshes  (Read 25225 times)
Offline dennisvolkerts
Re: Script for rendering deformable meshes
« Reply #15 on: June 24, 2016, 05:01:47 am »
what version of KeyShot are you using? Make sure that you are on the latest version 6.2.85. It was just released.
I tried the latest version after you said.
But now some materials I assinged at the first frame changes in other materials.
damn... already try to get my animation to render for 2 days.
And even now it stops at 6 frames or so.... ( no crash just an error that I need to reinstall keyshot and that it cant import abc files) after restart keyshot.. its fine again for some frames..
is there a shotcut for script console running script?
...ohh wait, after getting everything in the que i get another error... after hitting ''Process Que'' just after update. : Cannot load library luxrender.so
EDIT:
I finaly after alot of crashes made it.
« Last Edit: June 30, 2016, 05:53:03 am by dennisvolkerts »
Offline LayC42
« Reply #16 on: June 30, 2016, 10:32:17 pm »
This dancing granny is so good. It's amazing!
« Reply #17 on: July 01, 2016, 02:56:26 am »
THNX :-)
Offline TpwUK
« Reply #18 on: July 01, 2016, 06:29:41 am »
Excellent result Dennisvolkerts - May I ask how you got the materials to remain across frames as I have this issue with my script and i can't find another way round the problem ?
« Reply #19 on: July 01, 2016, 08:00:23 am »
I had the same problem. Had to rerender the eyes and composit it on top with a clowpass.
Sometimes its better to begin from scratch and save the materials you used in the library to apply it again in the new scene
First i imported the whole scene as abc file... but its also better to only import the deformable mesh in the abc and import the enviroment as a different obj.
Offline philw
« Reply #20 on: August 03, 2016, 11:27:52 am »
Hi all - chanced upon this whilst looking for a C4D export to Keyshot animation and working well - many thanks. However, I would like transparent PNGs like I can check in the standard render dialogue...am I missing something or is there something I can add to the script to enable it?
Cheers!
Offline bdesign
« Reply #21 on: August 03, 2016, 11:42:40 am »
Superb animation! Love it!
Eric
Offline philw
« Reply #22 on: August 03, 2016, 11:05:26 pm »
Cheers!
After doing some tests I found that having the alpha transparency option ticked in the render dialogue actually works for the script, even though not seemingly part of the process. Result!
Online DriesV
  • Administrator
  • Total likes: 19
« Reply #23 on: August 05, 2016, 10:35:13 am »
Here are two revisions of the script.
They provide the ability to update multiple Alembic models in one scene. They also have options for render passes/layers and you can specify an output folder.
The difference between the two scripts lies in how import is handled. One script allows browsing individual Alembic files (up to 4, but number can be changed inside the script), the other automatically loads all Alembic files that are contained in a folder.
Have fun!  :)
Offline philw
« Reply #24 on: August 05, 2016, 11:51:59 am »
Thank you!
Offline JMAHIEDDINE
« Reply #25 on: August 25, 2016, 05:20:32 am »
Thanks DriesV. Is it the same script as the obj sequence one you did ?
If no, what is the best option in your opinion, to import a clean animation with deformation in keyshot?
Thanks,
Cheers,
John
« Reply #26 on: September 20, 2016, 07:24:06 am »
Im gonna try it. I have one question.
I mentioned on the first script, that while it is rendering my que it also was still rendering my first main frame. Is that solved in the NEW ones?
Or is it possible? thnx
Offline Niko Planke
  • Software Tester
  • Global Moderator
  • Full Member
  • Total likes: 0
  • QA-Lead, Luxion
« Reply #27 on: September 20, 2016, 07:42:59 am »
Hey Dennis.
That issue should be resolved in the latest KeyShot 6 version (6.2.105)
Can you please Check for updates and try again?
« Reply #28 on: September 21, 2016, 06:33:13 pm »
Hey Dennis.
Thnx!!! it worked. :)
Another two realy importend things,
-it doesnt always update the animations ( its still a bit buggy ) sometimes I render for hours and I only see the first frame with camera animations.
-Another and the most horrified thing: it doesnt save any files sometime..
« Last Edit: September 21, 2016, 06:35:17 pm by dennisvolkerts »
Offline Artur
« Reply #29 on: September 22, 2016, 12:04:20 am »
Hi Guys.
Do This scripts works in the OSX version of Keyshot?
