Author Topic: Lighting issue  (Read 2491 times)
Offline number12
  • Jr. Member
Lighting issue
« on: February 24, 2015, 10:04:17 am »
Hi guys,
I'm trying to light a banana slice (soft touch texture which is base texture) which then has a texture map wrapped around it and for the sliced area (top) I am using a label. I'm then setting up a custom light and am trying to create a nice side light to light the side of the slice but once the label is added I have to set the intensity of the first light (on the side) to MAXIMUM to make it appear at all. I wanted to know, is this a bug or am I doing something wrong??
Offline Rex
  • Global Moderator
Re: Lighting issue
« Reply #1 on: February 24, 2015, 11:14:15 am »
I'm not exactly following the setup. What type of material is the banana? Can you share your scene? Send the .ksp to [email protected] for me to take a look at.
