Technical discussions => Rendering => Topic started by: JHoagland on September 07, 2013, 10:50:33 am
Title: Need help with skin material
Post by: JHoagland on September 07, 2013, 10:50:33 am
I'm trying to figure out the best skin materials setting.
Here's a sample image showing a comparison between Keyshot and PoserPro 2012. The Keyshot image seems dull in and doesn't seem to "pop". PoserPro uses sub-surface scattering and translucency on the skin, which I can't figure out in Keyshot.
I use the "Advanced" preset in Keyshot with a texture map. I tried adding a bump map but it didn't make much difference. I also tried using the Translucent preset, but that didn't really look good.
The lighting is the default scene in Keyshot.
Does anyone have any suggestions or ideas about how to make realistic skin?
--John
Title: Re: Need help with skin material
Post by: Ed on September 19, 2013, 10:38:29 am
John,
Did you try the KeyShot Human Skin material in the Translucent folder?  It has subsurface scattering.
Ed
Post by: JHoagland on September 26, 2013, 01:20:31 pm
Thanks for the suggestion, but whenever I use any of the Translucency presets, I can see a seam line where the materials meet.
But I'll use this as a starting point. :)
--John
