Technical discussions => Materials => Topic started by: topsecretagent on December 11, 2018, 09:20:32 pm
Title: Rendering Clear Plastics with Backplate
Post by: topsecretagent on December 11, 2018, 09:20:32 pm
Hello!
Could someone please help explain why clear plastic materials are showing a dark area (on the right side) when using a backplate image? This doesn't happen when rendering on a color background.. adjusting ray bounces does nothing. Global illumination is on.. I can't seem to find any information regarding this issue! Anyone else encountered this?
Any help appreciated!!
Title: Re: Rendering Clear Plastics with Backplate
Post by: kiarash.tamizkar on December 13, 2018, 06:20:51 pm
it is because of thickness of glass and Fresnel effect ,its normal
Post by: RRIS on December 17, 2018, 02:25:53 am
Does it look any different when changing the material to solid glass?
Post by: Will Gibbons on December 18, 2018, 08:04:56 am
It's because they're reflecting the dark areas in your HDRI (a backplate doesn't get rid of HDRI reflections). You could use this image as the background of your HDRI and then the dark areas would be colored to match your HDRI instead.
