Technical discussions => Materials => Topic started by: Jikkk on April 29, 2018, 02:25:27 am
Title: Combining Two Opacity Maps
Post by: Jikkk on April 29, 2018, 02:25:27 am
Hey, everybody!
How to combine two (or more) opacity maps? I've been experimenting with the Color Composite node with all types of Blend Modes but nothing worked.
Thanks!
Title: Re: Combining Two Opacity Maps
Post by: INNEO_MWo on April 29, 2018, 09:30:17 pm
Hello Jikkk.
I guess you’re on the right track.
What are the resources for the composite node?
You can also combine several procedural textures.
Or use a color to number node between the composite node and the opacity channel.
If you tell us which version of KeyShot do you use, I can post an example.
Post by: Jikkk on April 30, 2018, 01:49:28 pm
Hey!
My inputs are two Mesh textures with different setting (Circular and rectangular). I am using KeyShot Pro 7.2.
Post by: INNEO_MWo on May 01, 2018, 02:53:11 am
Yeah! Does it work as you expected?
Post by: Esben Oxholm on May 01, 2018, 03:11:36 am
Hi Jikkk.
I just tried this out and can see that it at first behaves a bit differently than if you've used bitmaps.
I found that if you in each mesh texture change the alpha mode to 'opaque', then they will blend like regular bitmaps.
Let me know if it works for you.
Cheers,
Post by: Jikkk on May 01, 2018, 12:13:35 pm
Thanks Esben..
It now works like it should be. You're a Keyshot master!!!!  :)
Post by: Jikkk on May 01, 2018, 12:14:57 pm
Hey Marco. Esben tip works. Thanks anyway!
Post by: Esben Oxholm on May 01, 2018, 11:03:35 pm
Thanks Esben..
Great, good to hear!
Post by: Finema on May 01, 2018, 11:12:19 pm
Thanks Esben for this tip  ;)
Post by: INNEO_MWo on May 02, 2018, 08:16:53 am
Glad to see, that this works.
It is a lil different if you write on a mobile phone or have an access to a system to test.
Esben's doin' right!!!
