Technical discussions => Lighting => Topic started by: Zvi on January 25, 2018, 05:54:37 am
Title: Can't see the IES light on the models
Post by: Zvi on January 25, 2018, 05:54:37 am
I can't see the IES light on the models, as you can see in the attached image.
Title: Re: Can't see the IES light on the models
Post by: INNEO_MWo on January 25, 2018, 11:18:38 pm
Do you enabled Global Illumination? (Like the product lighting preset).
Is the part with the IES light intersecting a solid material?
Post by: Zvi on January 26, 2018, 03:35:45 am
Yes to all. I attached the ksp file here.
Post by: Will Gibbons on February 01, 2018, 10:59:06 am
In your image, it looks like the IES light is not pointing to the ground. I'd rotate the object the IES light is applied to to make sure it's illuminating the ground (or whatever you wish to point it toward).
Post by: Zvi on February 01, 2018, 11:30:26 am
The light is pointed to the model. THERE IS NO REASON TO BE POINTED TO THE GROUND.
Post by: Will Gibbons on February 01, 2018, 05:51:02 pm
Just to be sure... you know the light comes out of the wide part, right? Not the pointy part.... In your image, the light is pointing to the left.
Post by: Zvi on February 02, 2018, 03:05:16 am
You were right, I had to rotate the light. Thanks.
