FEATURES
Amazing rendering and animation. In real-time.
What Makes KeyShot Different?
KeyShot is designed to make 3D rendering and animation easy. It allows you to apply materials and lighting fast and provides the most accurate materials appearances and real-world lighting, all in a powerful interface that provides advanced capabilities and the ability to see all your changes in real-time. So, what is KeyShot? And what does it help you do?
Focus on your design, not software.
KeyShot is extremely easy to learn and use to achieve photographic results in minutes through a simple, workflow-based interface with all the advanced capabilities for the most experienced 3D render professional.
Learn More
Present your ideas sooner.
KeyShot brings visual speed and agility to the entire product development process, with the widest 3D file format support for a fluid workflow from concept to final product.
Learn More
Make it more realistic.
KeyShot materials go beyond physical appearance providing scientifically accurate properties for the highest quality visuals. Use a preset, an exclusive partner material or create your own.
Learn More
Access complete computing power.
KeyShot gives you the power and the choice to utilize either CPU or NVIDIA GPUs for rendering and the capability to scale linearly for unmatched performance.
Learn More
Light it up right.
KeyShot provides advanced lighting capabilities that create the most accurate lighting for simple studio shots or the most complex interior lighting.
Learn More
See your results instantly.
KeyShot is real-time rendering to the core. Not a mode. Not an afterthought. See everything as it happens. Every change from material and lighting to cameras and animation is seen instantly as you work.
Learn More
Leave them speechless.
Feature by Feature
CPU Rendering
Real-time ray tracing using all available physical and virtual CPU cores that scales linearly as more cores are added.
GPU Rendering
One-click switch to GPU mode for real-time ray tracing using all available NVIDIA RTX graphic cards.
Denoise
Deep learning noise removal on the Real-tiime View and render output for smoother results in less time.
Scientifically Accurate
Scientific accurate materials that represent properties like IOR, dispersion and subsurface scattering.
Global Illumination
Indirect light bounces between 3D geometry and allows other geometry to be illuminated when under transparent materials.
Focused Caustics
Show how light is affected by your materials with real world caustics immediately visible with a flip of a switch.
HDRI Lighting
Light your scenes quickly. Drag and drop a KeyShot HDRI environment into the scene and adjust as needed.
Physical Lighting
Add area, point, IES or spotlights by applying a light material to any piece of model geometry.
Material Library
Over 700+ material presets from architectural, cloth, glass, and gem to liquids, metals, plastic, and wood.
Texture Library
Access to textures for bump, color, displacement, IES light profiles, OpenVDB, roughness, labels and more.
Environment Library
More than 60 high resolution HDRI environments or edit to create your own with KeyShot Pro.
Color Library
Enhance your materials by using industry standard color libraries from Pantone and RAL, exclusively in KeyShot.
3D Model Library
Add context and detail to your scene quickly using a wide variety of models with complete materials and textures.
Exclusive Content
KeyShot includes exclusive content like Axalta Paints, Mold-Tech Textures, Sørensen Leathers, and Poliigon Textures.
KeyShot Cloud
Search and share KeyShot assets including materials, HDRIs and backplates, and download to KeyShot.
Favorites
Make collections of your favorite materials, colors, environments and textures for use in other scenes.
Procedural Textures
2D and 3D procedural textures from cloth, mesh and scratches to wood, gradient, camouflage and occlusion.
Cutaway
Expose the inner workings of your design with dynamic cutaways, set what to exclude, and add animation.
Scattering Media
Add particle scattering like smoke and fog with density texture and VDB support or use to create interesting materials.
RealClothTM
A powerful, new material type which allows the creation and visualization of realistic woven materials.
Toon Shading
Create non-photorealistic renderings suited for technical documentation, patent drawings and more.
Interactive Scene Tree
All parts, lights, cameras and animations in one place, with live search, filtering and grouping capabilities.
Interactive Labeling
Position labels on objects using their own material definition or adopted from the properties of the underlying material.
Dynamic Texture Mapping
Map textures across bump, color, specular, and opacity channels for the ultimate real-world appearance.
Material Templates
Patented technology to set up templates to automatically assign materials to the imported models on import to KeyShot.
Rounded Edges
Turn sharp edges on an imported model into beautiful, small rounded edges and fillets with simple slider.
Patterns
Create 100s or 1,000s of independent model instances without affecting file size, memory or speed.
Image Styles
Create multiple image styles with tone mapping, curve, color adjustments, or layers. View in real-time or adjust after.
Unlimited Resolution
Unlimited real-time and render output resolution with presets for common sizes and custom resolution creation.
Camera Control
Simulate real world camera behavior with different mode and controls applied in real-time to capture the perfect image.
Shift Lens
Use the shift lens to adjust your vertical edges or use a single click to adjust them automatically.
Walkthrough Mode
Set your eye height and turn on ground/collision detection to move through your scene.
Importers
KeyShot has the widest support for the direct import of over 20 native and neutral 3D file types.
Plugins
A direct connection between 3D modeling software and KeyShot with many including LiveLinking.
LiveLinking
Through select KeyShot plugins, keep your geometry changes updated in KeyShot without losing any work.
Network Rendering
(Add-on) Use your computer network to render your projects in a fraction of the time.
Learn More | Buy
Studios
Set up your own personal studios with any combination of cameras, environments, model sets and materials.
Model Sets
Set up different variations of the models in your scene to show different model configurations or create color studies.
NURBS rendering
For the ultimate quality and zero tessellation, KeyShot supports the import and render of NURBS data.
Geometry Editor
A secondary OpenGL viewport that allows camera path movement and geometry editing of the imported model.
Displacement
The Displace geometry shader allows you to create 3D textures for enhanced realism.
Bubbles
Bubbles can be added and configured to create everything from foam to fizz.
Flakes
Add any variety of flakes (square or spherical) inside your material or around it.
Fuzz
Add randomized, hair-like growth from the surface of any material, control length, density and more.
Multi-Materials
Create multiple variations of your materials for quick color comparison or advanced colorway creation.
Configurator
Use your material, model, and camera variations to create unlimited configurations.
Stereoscopic View
Set up stereoscopic 3D viewing to view or work in 3D space with a VR Viewer or HMD.
Perspective Matching
Interactive perspective matching tool that allows you to align the object in the scene with the photographed objects.
HDRI Editor
Lighting presets and full HDRI control with light pins, blur, highlights and the ability to enhance or create HDRIs.
Sun & Sky
Interactive Sun & Sky generation with date, time, and location, or place the sun where you need it in the HDRI.
Material Graph
Create advanced materials using KeyShot’s node-based editor to layer and animate materials and textures.
Scripting
Deeper functionality available through the Python scripting console to unleash the power of KeyShot.
Real-time Region Rendering
Select and concentrate your computer power to render small areas of your scene and see the results in real-time.
Render Passes
For more post-processing control, KeyShot includes render passes, like clown, depth and normal pass.
Render Queue
Store all your scenes prepared through the day and process the entire batch of when you’re ready.
3D Export
Export your scene as OBJ, FBX, GLTF, or STL to use in other software, view online, or 3D print.
Part & Camera Animation
Patented animation system to create part and camera animation using real-time setup and playback of your animation.
Camera Path Animation
Create camera path animations by selecting existing views or dynamically creating the path in real-time.
Panorama Animation
Create first-person rotation animations with a click using the camera itself as the rotation pivot.
Curve Fade
Use a custom control curve to change between two colors, across a range of colors or change a material’s opacity over a specific duration.
Zoom Animation
The Zoom camera animation allows for the dynamic change of the camera’s field of view for more dramatic animations.
DOF Animation
Depth of Field animation allows for the dynamic change of the camera’s focus distance and F-stop values.
Camera Switch Events
Set up camera switch events in a single scene to quickly switch between multiple camera animations.
Motion Blur
Create real-time motion blur with quick settings to deliver the ultimate realism when displaying moving parts.
Interactive Visuals
Create web-ready, touch-enabled visuals directly from your KeyShot scene with an array of unique features.
360° Spherical Experience
KeyShotXR goes beyond turntable views. With KeyShotXR, create true, fully spherical 360° product experiences.
Touch Gesture Control
KeyShotXR is completely touch-enabled and works across mobile, tablet or larger touchscreen displays.
KeyShotXR Wizard
With six different KeyShotVR types, create turntable, spherical, animated or custom KeyShotVRs step-by-step.
Responsive Embed
When you embed your KeyShotXR, it sizes correctly to the width of a browser whether on desktop or mobile device.
Preserved Image Quality
When you zoom in on your KeyShotXR, the image quality is preserved to ensure every detail is captured.
Interior KeyShotXR
A KeyShotXR that uses the camera itself as the pivot center to capture first-person view of the scene.
iBooks Support
Advanced iBooks widget output to embed a touch-enabled product experience in Apple iBooks files.
The rendering speed you need.
